08-26-2009, 11:36 PM | #1 |
How much ATF in torque converter?
How much fluid should I put in a rebuilt torque converter?
08-27-2009, 01:09 AM | #2 |
60-66 Nut
Re: How much ATF in torque converter?
Usually just dump a quart in it, then slide it on the input shaft. Make sure you get it all the way on. The front of the torque converter should be about 1 1/4" inside the front of the trans to engine surface.
08-27-2009, 08:47 AM | #3 |
Intentionally Left Blank
I usually put enough in until it runs out when you hold it horizontal. Some of the bigger ones take a little more, some smaller ones, not so much. Put a little on the outside of the snout where the seal sits too. It'll help keep from tearing the seal when you slide it in.
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
08-27-2009, 10:00 AM | #4 |
283 Drama Queen
Not knowing any better - I think I put 3 quarts in the converter of the TH350 before putting it in. A bit slopped out but it was no big deal. Because of the big pan the builder put on the tranny, I put in about 4 more before firing off the new motor for 20 minutes. Took another case of B&M 'Trick Shift' to the transmission shop - when the flat bed picked up the old girl, back in early July.
Hope to see her again...........someday. Mac.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
