Old 08-27-2009, 01:21 AM   #1
Bennydog
Bennydog's Avatar
disc brake question
I have a 65 c-10 with drums looking to get discs up fron. I have an opportunity to get a brand new front end disc 2 inch drop spindles tie rods ball joints ect... from cpp. it is on a 1960 c-10 does anyone know if the parts are interchangable before i go get them.. thanks in advance
Grandpas and Dads and now my 1965 C-10
1975 SWB C-10
Bennydog is offline   Reply With Quote
Old 08-27-2009, 02:24 AM   #2
63deluxfleet
63deluxfleet's Avatar
Re: disc brake question
i know for a fact that the 60 is a torsion bar suspension and yours is a coil suspension so i don't believe that you would want that. not an expert but maybe some one else can chime in
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield
.......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS.....
63deluxfleet is offline   Reply With Quote
Old 08-27-2009, 07:25 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
I agree with 63deluxfleet - CPP lists the 60-62 as one flavor and the 63-70 under a different assembly number. I don't believe the early version is going to be a direct fit on your suspension.
If the deal you're getting is a real bargain, it might be worth calling CPP to find out what the differences are. There might only be a couple small items you'd need which could still come cheaper than buying a whole kit retail.
Old 08-27-2009, 10:12 PM   #4
griffman
call this guy he sells disc brake kits for 60 thru 66 complete bolt on very nice set up and hes very good on his prices and will talk to about it not just sell it and never answer ur questions call tim at 1-559-824-5289 tell him steve from modesto told u about him thanks
griffman is offline   Reply With Quote
Old 08-28-2009, 12:52 AM   #5
Captainfab
60-66 Nut
If it's on a torsion bar front suspension, I don't believe they'll work on your '66.
If you want discs with a drop, just buy the drop spindles from a reputable seller like McGaughy (they make spindles) and the rest of the parts are off the shelf items at your local auto parts store.
Old 08-28-2009, 11:22 AM   #6
C10Slim
Is it really that simple? Just buy disc parts for like a 72+?
C10Slim is offline   Reply With Quote
Old 08-28-2009, 11:31 AM   #7
70 Suburban
Rods
Originally Posted by c10slim View Post
is it really that simple? Just buy disc parts for like a 72+?
if you use 72 its a bolt it
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 08-28-2009, 11:45 AM   #8
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
First thing to find out is if the donor '60 has a later, coil spring front end already swapped under it.
Larry
fleetsidelarry is offline   Reply With Quote
Old 08-29-2009, 01:56 AM   #9
Captainfab
60-66 Nut
Yes it is.....you just need '71-'87 front suspension parts starting with the ball joints and it will all bolt right on your '66 control arms. Or if you want to upgrade the control arm bushings to the later style you can install them onto your existing crossmember. Of course when you upgrade to discs you will have to upgrade the master cylinder/combination valve as well.
Essentially you don't have to spend the big bucks to get front disc brakes on your truck.
