Old member
Here is a picture of the wiper tool you can use to get the wiper arms off with. I have never pulled any kind of pin out and there is nothing broke off of them. I use to use the screw driver to pry them off with, until I found this tool for $3.00 at the parts house and it doesn't chip the paint. Hope this helps everybody out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
That looks like a tool that will work!
Is that a plastic grip in the middle which prevents scratching of the wiper arm? Thanks for posting the info! Jim |
Do it well or don't do it
I like that. What parts house or brand and part number?
Try to be the person your dog thinks you are. Excellent paint and body site: http://www.autobody101.com/ Visit my Web Site http://home.attbi.com/~agfosteriii |
Old member
Yes it has the rubber covering on it to keep from scratching the arm. I bought it at napa off of the shelf, I don't think it has a part number. It was out front in the store.
December 21, 2012
There is also another tool that looks somewhat like pliers. You put the end under the wiper and squeeze them like a pair of pliers and the end under the wiper opens and pops the wiper off.
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
