Old 08-27-2009, 03:05 AM   #1
63deluxfleet
63deluxfleet's Avatar
wheels hubcap interchange
hi i found a set of wheels in this style 4 for 20.00! this is not the actual pic. used for reference. what does it run to powdercoat wheels? they are 6lug. i was wondering if i would be able to use hubcaps from the 50's style trucks. will they work with these? also i saw websites for vintage hubcaps like the nude ladies and hollywood moons will these work on these types? they are 15's thanks.
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield
.......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS.....
63deluxfleet is offline   Reply With Quote
Old 08-27-2009, 06:31 AM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: wheels hubcap interchange
With the older Chevrolet knub rims the stock hubcaps are interchangable. Usually 10 1/8" diameter on the inside of the hubcap.
Old 08-27-2009, 07:55 AM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I am running a set of 80's sixlugs like that , and the original hubcaps on my 65.
just make sure the hubcap is not the clip on style.
Old 08-27-2009, 07:07 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
I believe the 50's style Chevy truck hubcaps are all clip style and won't fit those wheels. My 1960 GMC was originally equipped with clip caps. Anything of the Chevy passenger car caps from 54 up will fit, and also from Ford (they all share the 10 1/8 size), also the dog dish caps from Olds, Pontiac, etc. I'm not sure when Chevy trucks went to nub style wheels, but I'm guessing 1963, so anything from then on should fit. I've used 1954 and 1960 Chevy car caps and they fit fine.
The earlier style wheels (usually pre-disc brakes) have 3 bumps on the wheel center to hold the cap. The newer disc brake wheels have 4 bumps. These stretch the cap a bit tighter but still work. Baby moons work fine, including the Chevy baby moons that had a bowtie embossed in the center.
The naked lady and moon caps are generally wheel covers, not hub caps and they will almost any 15" wheel since they are held on with spring fingers around the rim.
Old 08-27-2009, 08:24 PM   #5
63deluxfleet
thanks for the input. does anyone know a ballpark figure on powdercoating these wheels? just thought id ask!
Old 08-27-2009, 08:34 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I get about 40 a wheel in a basic color. I'm not trying to wrangle work though, I'm quite booked up right now.
Old 08-28-2009, 12:27 AM   #7
Captainfab
60-66 Nut
The powder coater I use gets $150-60 (depends on the color) a set to blast and powder coat.
Old 08-30-2009, 06:58 PM   #8
Micmac
Micmac's Avatar
Anyone know where I can get a set of hubcaps for my 63? Will 61's fit?
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
