Old 08-27-2009, 03:27 PM   #1
Mark B
Mark B's Avatar
Where is switch for reverse lights?
I have a 1970 C10 with a 250ci six and three on the tree? Anyone know where the switch is for the reverse lights (back up lamps)? Is it on transmission or maybe the steering column?
thanks
Mark
Mark B is offline   Reply With Quote
Old 08-27-2009, 03:53 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Where is switch for reverse lights?
bottom of the steering column
Old 08-27-2009, 05:47 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
why when i back up in reverse my backup lights dont come on?
John
1999 Toyota Tacoma 4x4
Old 08-27-2009, 05:51 PM   #4
fixit-p
fixit-p's Avatar
Three on the tree as in manual trans should be on the tranny.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 08-27-2009, 06:03 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Mines on the lower part of the column.IIRC it is on top where it's hard to see or get to.If the lights aren't working try adjusting it first.It adjusts by loosening the bolts and sliding it slightly.You need to have the key on and the tranny in reverse.Then when they light the adjustment should be good.Tighten the bolts and shift out to be sure they go off before putting the tools away.If this doesn't work try jumping the two wires going to it.Then you can be pretty sure the switch isn't causing the problem.It's a fun position to get into so be sure and take everything with you the first time.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-27-2009, 06:06 PM   #6
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: Where is switch for reverse lights?
my 67 3spd on the column has the switch on the steering column , it is factory because I ordered a new one at NAPA but when I took it apart the only thing wrong with my old one was it had the little tab broke off , I put the tab back on with JB WELD in 06 and it has worked fine since ,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 08-27-2009, 06:07 PM   #7
71swb4x4
71swb4x4's Avatar
The way you wrote this leads me to believe that when you back up in a forward gear the backup lights do come on...
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
