Old 01-12-2003, 03:09 PM   #1
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Clutch question
Will a 11in clutch work with a 12in pressure plate and a 12in flywheel?
Ben
67Fleetsidedream is offline   Reply With Quote
Old 01-12-2003, 04:25 PM   #2
crazy longhorn
Fabricate till you "puke"
The 11 & 12 " clutches fit the same flywheel(14" diam, 168 tooth ring). The12" disc is larger , & the press plate is larger, & also scalloped to fit the same bolt pattern as the 11" setup.....I dont think I would mix the pcs tho, go all 11", or all 12" on the parts. good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-12-2003, 04:34 PM   #3
67Fleetsidedream
Let me see if I am getting this right. So I can buy a 11in pressure plate and clutch and it will bolt to a 168t/12in truck flywheel?
All I am wanting to do is convert my clutch from a 10 spline to a 26 spline. I was thinking that I would need to get a 11in flywheel, 11in clutch and a 11in pressure plate to make this conversion. Do I have it all wrong?
Thanks again
Ben
Old 01-12-2003, 04:41 PM   #4
crazy longhorn
Yes, you can bolt an 11"clutch setup on the same flywheel where the 12" came off. the bolt pattern is the same .....crazyL
Old 01-12-2003, 05:47 PM   #5
67Fleetsidedream
Great!!! So I don't need a new flywheel, just a 11in clutch with a 26 spline input and a 11in pressure plate.
I wonder what came with this setup from the factory????
Would anyone know?
Thanks again
Ben
