Old 08-27-2009, 05:34 PM   #1
threeonthetree
threeonthetree's Avatar
What should i cut coils with?
im about ready to cut my coils for a 3inch drop
and im not sure what to use
ive heard do not to get them hot or use a torch
cutting wheels ive heard
will a saw za do it?
and how many coils
ive heard a coil and a half will do it.
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 08-27-2009, 05:50 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: What should i cut coils with?
cutting wheel. just make sure you take your time and let don't allow the coil to get too hot in the cut region. slow is the way to go.....
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 08-27-2009, 05:56 PM   #3
mclairmo
Cutting wheel and keep the metal cool, maybe wrap the bottom of the coil with a wet towel or submerse bottom of coil in a bucket of water; just don't eletrocute yourself. I always thought that you cut one coil per inch of desired drop. Someone please correct me if I am wrong.
mclairmo is offline   Reply With Quote
Old 08-27-2009, 06:04 PM   #4
71swb4x4
71swb4x4's Avatar
I know it can be a pain to remove and install the springs, but I would recommend cutting one coil, reinstalling, and driving for a week to let it settle. See if that's enough. If not, pull them out and cut another coil, or even a half coil.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-27-2009, 06:23 PM   #5
Ackattack
Ackattack's Avatar
I wouldn't worry about heat build up using a cut off wheel.
Ackattack is offline   Reply With Quote
Old 08-27-2009, 06:59 PM   #6
kev2809
low n' slo
kev2809's Avatar
agree. i think a cut off wheel would be best since a coil isnt that big across and dont produce a whole lot of heat. at least not enough to mess anything up.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 08-27-2009, 07:08 PM   #7
tnblazerk5
User #12137
tnblazerk5's Avatar
i used a band saw and cut 1 1/2 coils the first time and it was way to low the 2nd time i cut 1 coil and it was just rite its about 31/2 or 4 inch lower in the front now
i had to also cut the metal stand and the bump stops off both lower control arms and replaced them with Energy Suspension bump stops
tnblazerk5 is offline   Reply With Quote
Old 08-27-2009, 07:49 PM   #8
tcb-1
tcb-1's Avatar
remember! cut less than you think you'll need! just a half a coil brings these springs down quite a bit.
Doug
Old 08-27-2009, 08:04 PM   #9
mvfd70
mvfd70's Avatar
Nothing was mentioned about rear springs. Remember that you cannot cut the rear springs. You didnt say front or back so this is just a reminder that they can't be cut.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 08-27-2009, 08:11 PM   #10
69 longhorn
Toss the coils upside down in a 5 gallon bucket of water, torch 1 full ring off the bottom.....after the springs "settle in", you will have a 3" drop crazyAl
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 08-27-2009, 08:15 PM   #11
69 longhorn
What he said.....on che cheap, you can run a 2 " block on the rears. best of luck
Old 08-27-2009, 08:28 PM   #12
mclairmo
I just saw a pic on another post today of a guy who cut the ends off another set of trailing arms to make himself a set of lowering blocks. Pretty cool.
Old 08-27-2009, 09:07 PM   #13
kev2809
low n' slo
kev2809's Avatar
why can't u cut the rear springs? not questioning u, I just never knew that
-_--_--_ _________
Old 08-27-2009, 09:11 PM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Because the coils get tighter on the ends. If you cut the ends off, the coil retainers won't fit into the ends of the spring to hold them in.
Old 08-27-2009, 09:28 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i've used a torch, sawzall, and cut off wheel.
Cut off wheel is prefered IMO.
Heat is second, if you now how to ue a torch, then you won't heat it up enough to do any damage. (that 'damaged from heat' is WAY over rated, you'd have to be a real tool to damage them if lowering with heat alone)
Sawzall is last on my list just due to being a bit harder to control.
Old 08-27-2009, 09:46 PM   #16
69 longhorn
Andy, does knowing how to use a torch mean that you have never had a car or truck on FIRE! Thats one I guess I can NOT say(not without tellin a bare face d lie anyway! LOL crazy Al
Old 08-27-2009, 10:07 PM   #17
Longhorn Man
well, we had this fuel truck in the shop one time... and I figured, *heck* I'm working on the front of the *darn* truck... I ain't scared.
Yeah... I almost crapped myself when i saw the flames out the corner of my eye... under the cab.
Been there, done that.
First time I tried welding sheet metal was a striker post on an international 4900 fuel truck. (anyone notice a trend here?) The funny thing is, the back wall of the cab has a panel covering the lower part of the wall, under the window... and insulation in there... yeah, i blew through, and it cought fire... and again, I almost soiled my pants.
Old 08-27-2009, 10:38 PM   #18
threeonthetree
well i used the cut off wheel and it went faster than i thought
so this is where im at now which i want to be lower
how long will it take the springs to "settle in"?
im sitting at 31" or somthing and i my rear is gonna be like 29" when i get the drop
should i take a half coil off?
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 08-27-2009, 10:46 PM   #19
69 longhorn
Well there you go,.....got to love an honest man I like fire, but over the last 30 yrs it has scared this crazy old man at least a time or 2 crazyAl
Old 08-27-2009, 11:43 PM   #20
Gearhead dude
Gearhead dude's Avatar
How much did it drop it?
Gearhead dude is offline   Reply With Quote
Old 08-28-2009, 12:41 AM   #21
threeonthetree
i didn't take a measurement before i wasn't thinking and i already had it on the jackstands and both wheels off b4 i remembered to.
what is a stock ride height from fender to the ground?
mine is at 31'' now.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 08-28-2009, 08:27 AM   #22
Gearhead dude
Mine's at 32 1/4" front and 31 1/4" rear. Both measurements to the center of the fender opening above the wheel centerline.
Old 08-28-2009, 10:42 AM   #23
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Don't you think it's dangerous to drive with such a large side mirror????? They say "objects are closer than they appear". It seems that everything would look like a semi-truck in that thing!!!
Just had to take a shot at a funny this morning. Reminds me of the ferrari testy mirrors. Nice stance, buy the way!!!
prostreetC-10 is offline   Reply With Quote
