![]() Join Date: Nov 2008
NP205 T-Case question
I have a late model SM465 transmission with the 32 spline output. I'm looking to put a NP205 on it but, need to make sure I'm buying the right one.
Which variant of the NP205 will work with this transmission?
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
Re: NP205 T-Case question
Do you have the adapter? There are two different input shaft lengths for the 32 spline input. I think the late model ones are the Long input shaft. I could be wrong, i had to change mine from the short input to the long input
71 swb 4x4, 37" Iroks, t400/205 496 77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20 |
You will need the long input and adapter....Came out in 85, 86 at the least, that is what mine is.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
So any 205, a long 32 spline female adapter and the adapter and you will be good. Tall order. So i think a later model 4 speed 205 and adapter is what you need.
![]() Join Date: May 2007
It should be a round bolt pattern not the figure 8.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
![]() Join Date: Jul 2008
Check out Advanced Adapters. They have pretty much every possible configuration avail. Their prices may seem expensive at first, but do some checking around and you'll probably find that they may be 50 to 80 bucks more far a new piece vs. a used one.
Thanks for all of the help. I decided to go an easier route, I found a great deal on an earlier 465/205 combo so, I'll be selling my late model 465.
