Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-27-2009, 07:26 PM   #1
82Cecil
82Cecil's Avatar
My fuel cell rocks... from side to side ( pic )
Before I press this curve out of the bottom of the cell, is this normal/needed?
I wouldn't think so but I've been surprised before.
82Cecil is offline   Reply With Quote
Old 08-27-2009, 09:57 PM   #2
Wild83C10
Wild83C10's Avatar
Re: My fuel cell rocks... from side to side ( pic )
Shouldn't be that way, who's cell is it?
The sump doesn't look straight, but it could be the picture.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 08-27-2009, 11:00 PM   #3
72 SUPER10
Sometimes happens when they pressure test it for leaks, does it say it has been tested ,
72 SUPER10 is offline   Reply With Quote
Old 08-27-2009, 11:14 PM   #4
Captainfab
60-66 Nut
It is also common to get a little bit of distortion when welding a tank like that. Especially when you have the additional welding around the sump. IMO it really doesn't hurt anything. Are any of the other sides distorted?
Old 08-28-2009, 05:34 PM   #5
82Cecil
82Cecil's Avatar
It is a 15 gal Jeg's brand, the picture does make the sump look crooked but it is not. The bottom is the only side with a bow in it.
I'm just going to press it flat.
Old 08-29-2009, 11:27 AM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
I guess I would ask 'why' you need it flat??????
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-13-2009, 05:56 PM   #7
mongoose
mongoose's Avatar
to make mounting it eaiser i suppose... as the tabs are on the bottom of the tank as well..
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-13-2009, 06:06 PM   #8
Wild83C10
Wild83C10's Avatar
I have mine sitting on aluminum tubing. This spaces it off the bed and I didn't have to cut the bed up too much. I only put holes in for for the fuel lines.
turbo=
Old 09-13-2009, 07:09 PM   #9
djracer
djracer's Avatar
Make sure you don't mount it by the tabs.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-13-2009, 07:49 PM   #10
truckpoorpackrat
I would think that curve is there to allow the fuel to flow toward the sump, if you turn the level up & down is it setting flush with the bottom (I think you are holding the level on the bottom of the tank in the picture)? Does that make sense? James
truckpoorpackrat is offline   Reply With Quote
