Old 08-27-2009, 07:50 PM   #1
62 short step
62 short step's Avatar
Interior
I'm putting new carpet in my truck and a few other things. I bought these kick panels from LMC, why do they have this bump on each side? As you can see the vent is not flush. What the h*ll is this all about? Has anyone put any in before?
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 08-27-2009, 08:21 PM   #2
sandfreek
Re: Interior
Looks like the ones you have are for a 64-66, they have a handle to open them and look diffrerent than yours...I havent seen a 62 so not forsure...
sandfreek is offline   Reply With Quote
Old 08-27-2009, 08:23 PM   #3
terd ferguson
terd ferguson's Avatar
Re: Interior
My truck didn't have the vent covers and I didn't know they existed til you posted. I don't know what the lump is for. But here's a way to fix it. You can cut the lump out and then weld some plastic from a donor piece of trim in it's place (like a patch panel). You can use a piece of trim from almost any auto. To weld plastic, you basically just melt it slightly and flatten it out with a screwdriver. Since it looks like you already painted the plastic, do it again after the repair. The cover up should be seamless.
I got the idea for plastic welding from an import car mag at the grocery store. I think it's got "project" in the title. The whole issue of the mag was about fixing up a CRX from the junkyard to the car show. The plastic "welding" trim repair part was pretty sweet.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 08-27-2009, 08:30 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Interior
How awesome is that ? You pay good money for parts then we get to figure out how to make them work. It could make a fellow bitter if he let it.
Old 08-27-2009, 09:02 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
Re: Interior
....64-66 have an arch across the opening for a handle that opens the door in the vent assembly. Those bumps would clear the hardware.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-27-2009, 09:39 PM   #6
62 short step
Re: Interior
Thats what I was thinking. I called them and there listed for 60-66. I should be recieving a call from LMC Friday to let me know what the deal is. I'll have to check my 66 to see if the vent covers are in it, i dought it though!
Yes it could make a fellow bitter to modify new parts!!
Can some one post a pic of a 64-66 vent cover?
1965 c-10
86 chevy c/k 20
Old 08-27-2009, 10:24 PM   #7
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
Re: Interior
Jeremy, I have a spare set of 64-66 vent assemblies, (don't know if they will interchange or not) but there is no vent cover. When you open the vents they pivot around and direct air into the cab and seal on the edges. Do you open the vents with a dash lever?
Kevin
65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride)
68 Chevy SWB Fleetside Custom Cab
68 Camaro convertible
65StreetCruiser is offline   Reply With Quote
Old 08-27-2009, 10:34 PM   #8
sandfreek
Re: Interior
The ones that you have look alot like the ones I had on a 59 I had way back...Maybe check to see if 55-59 kick panels would work with no mods...
Old 08-27-2009, 10:59 PM   #9
terd ferguson
Re: Interior
My '63 has the handles. I'm not sure if that's factory or not though.
Old 08-27-2009, 11:24 PM   #10
Northern lights
Re: Interior
My '64. Sorry for the poor shot but you can see that the "bumps" accomodate the vend lever.
Northern lights is offline   Reply With Quote
Old 08-28-2009, 01:14 AM   #11
Captainfab
60-66 Nut
Re: Interior
Those kick panels are for the '63-'66's. They are as in the pic above. The '60-'62's that are cable operated are what you have 62 short step. You could probably trim those to fit, but might be a PITA to make look right. Then again you shouldn't have to. If they advertise parts to fit a certain year(s) they should fit without modification.....unless they tell you they might need modified.
Old 08-28-2009, 08:18 AM   #12
62 short step
Re: Interior
Kevin, i need to check my 66 to see if they are still there. Yes it operates from the dash.
Thanks for the info and the pics, very helpfull. And yes they should change the catalog. I'm expecting a call from them today i'll tell them what they need to do. Hopefully the 63-66 vents will work, i'll let you all know when i get it figured out. Thanks guys!
1965 c-10
86 chevy c/k 20
Old 08-28-2009, 08:32 AM   #13
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Interior
I think the 63 to 66 vents will just bolt in, however I sure like the look of the 60-62 better...
the 63 -66 are designed so you can just kick it open with your foot.
Old 08-29-2009, 08:23 AM   #14
62 short step
Re: Interior
Well i have a set of 63-66 vents on the way. And of course LMC never called me Friday, and i forgot to call them myself.
1965 c-10
86 chevy c/k 20
Old 08-30-2009, 02:16 PM   #15
62 short step
Re: Interior
Here is some more progress. Getting the seat in, its out of a 99 suburban. Its the 2nd row seat. Had to borrow a seat base from an 88-95 chevy truck and make some brackets. I need to paint the seat base also.
1965 c-10
86 chevy c/k 20
Old 08-30-2009, 05:01 PM   #16
protrash64
protrash64's Avatar
Re: Interior
That interior is looking really nice! Probably wont want to get any mud in there now.......time for paint? I know what that means!!
Old 08-30-2009, 06:45 PM   #17
62 short step
Re: Interior
I'll just have to get some big floor mats to catch the mud! Getting close for paint!! It probably will not be hammer tone!
1965 c-10
86 chevy c/k 20
Old 08-31-2009, 03:26 AM   #18
jbgroby
jbgroby's Avatar
Re: Interior
Jer.
I have aset of the 63-66 vents if you need them. I bough them about a month back on a whim off ebay let me know.
Jake Groby
jbgroby is offline   Reply With Quote
Old 08-31-2009, 03:58 AM   #19
816allen
816allen's Avatar
Re: Interior
Dam those are my favorite seats, looking good!
Carpet looks cool, man real nice setup makes me wanna do mine up!
96 Burban Sold
99 Z71 Sold
65 C10 Sold
72 C10 Sold
87 Short Bed Lowered Daily Driver
http://s623.photobucket.com/albums/tt314/sswagon/
http://www.chevygmcofkc.org/forums/forum.php
816allen is offline   Reply With Quote
Old 08-31-2009, 04:48 AM   #20
Bazooka
Keepin it old school
Bazooka's Avatar
Re: Interior
Everybody changes the seat. I'd love to find a stock seat for mine. When I look at classic vehicals for sale I get pissed if somebody changed the seat I'd trade my seat for a stocker if anyone is interested..Its out of a 80s chevy PU I think. Thats what the previous owner said..
Bazooka is offline   Reply With Quote
Old 08-31-2009, 07:54 AM   #21
62 short step
Re: Interior
Originally Posted by jbgroby View Post
Jer.
Jake Groby
Thanks Jake, but Kevin is sending me a set. PM me yout addy Jake, i need to take care of those bezels.
Thanks!
I wanted to keep the stock seat but i did not want to spend 4 or 5 hundred bucks to get it recovered. I found this one at LKQ salvage for $46.13 with tax, so that was the way to go for me!
1965 c-10
86 chevy c/k 20
Old 08-31-2009, 09:40 PM   #22
ol Curt
Junior Member
ol Curt's Avatar
Re: Interior
62, where did you get your carpet, and how did it fit?
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 08-31-2009, 10:52 PM   #23
62 short step
Re: Interior
I got it from LMC, and the fit is pretty good. I'm pleased with it.
1965 c-10
86 chevy c/k 20
