Watchin the rust grow
![]() Join Date: Oct 2008
Dual fuel tanks
I have a 79 K10, with two fuel tanks. How can I tell if the one on the driver side, filler neck in the rear fender well, is that stock or is that something Farmer Joe rigged?
Sometimes I regret buying an old farm pick as a daily driver.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done ![]() 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
Re: Dual fuel tanks
My dad's had the same thing his was after market not factory. How do switch over the tanks his had a manual valve on the drivers side floor that you turned to go from one tank to another.
My Truck's not leaking its marking its territory! |
Re: Dual fuel tanks
Interesting. The reason I'm asking is because the 2nd tank does not pump fuel, I'm not sure if it's something as simple as a fuel pump or if it's in a switch the PO had put in.
Looking for more information, thankyou though.
Re: Dual fuel tanks
The switch may just switch over the gage sender. Have you followed the lines from each tank to see where they meet? Do they meet at a manual or electric valve?
Re: Dual fuel tanks
Also I believe that a 79 does not have a pump in the tanks it should only have one on the engine block.
