Old 08-27-2009, 11:30 PM   #1
Smokeshow_1984
starting my t-5 swap
Well ladies and gentlemen, I finally got sick of my horrible fuel milage with my 4.11's, so I bit the bullet and bought a donor car for the swap,a 3rd gen f body with a mild 350, and a t5, which brings me to my question. with a swb truck, anyone have any idea as to the required length of the driveshaft? I know, I know, get it installed first, then messure the distance, But, I dont like vehicles sitting around, waiting. Id like to know before I start ripping things apart.
Subsequently, a 74 250, and 3sp will be sitting around shortly.
Thanks, Ben.
Smokeshow_1984 is offline   Reply With Quote
Old 08-27-2009, 11:39 PM   #2
dan76
Re: starting my t-5 swap
No I don't know the measurement, however I'd recommend you not have a DS prebuilt until you are sure of the measurement. Most DS shops have a quick turnaround...especially in this economic climate. Check around and talk to recommended shops prior to needing the DS and get an estimate of cost and time to build.
dan76 is offline   Reply With Quote
Old 08-27-2009, 11:53 PM   #3
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
I agree get the stuff in and then get your shaft. That way you can measure length at ride height, compressed, and extended. I can get one built here in a day or two. Cost: a couple hundred for a new custom built, balanced, aluminum driveshaft.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 08-27-2009, 11:58 PM   #4
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I know Brad did a nice write-up on the T5 swap, but do not remember if he mentions the length. Take a peek in the FAQ area for the article if you have not seen it.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 08-28-2009, 05:52 AM   #5
andrewmp6
If your over 300hp you better baby that t5.
andrewmp6 is offline   Reply With Quote
Old 08-28-2009, 11:57 AM   #6
menace121978
menace121978's Avatar
X2... what year f body? the T5 was only offered behind the 5.0HO/5.0TPI motor i thought? something you may want to look into. the 5.7's were backed by the 700r4 or early th350... if i remember correctly.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 08-28-2009, 12:08 PM   #7
Pyrotechnic
Pyrotechnic's Avatar
The T5 is a good gas mileage trans because it's so light weight and relatively inexpensive, but forget about hard launches and powershifts. If you just launch it normally and slide smoothly into each gear, it should last. The 4.11's will work in your favor since they are doing more of the toque multiplication thus taking some stress off the transmission and clutch.
Also, the T5 can be built to hold more power, and I believe the TKO-600 (based on the T5) is a direct swap and is very strong (600 lb/ft torque rated) if you want to upgrade later on.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 08-28-2009, 05:23 PM   #8
big10ratrod77
big10ratrod77's Avatar
also if you dont know you would have to use a s-10 tail shaft so your shifter wont be in your seat
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 09-01-2009, 04:48 PM   #9
Smokeshow_1984
Ive read the write up. The seat/tailshaft clearance issue is really only an issue when using an Inline 6 with an fbody tailshaft.
With the v8 mounts, the t5 sits closer to the front of the truck.
Im not building a drag truck, just a fun cruiser, and, as it is now with just the 250, she doesnt get any traction on a hard start, so, Im not too worried about nuking the t-5.
The motor is a later 4 bolt, modified vortec head engine with 800 miles of run time.
