Old 08-28-2009, 12:19 AM   #1
BCOWANWHEELS
2 questions on 350 turbos
MY FIRST QUESTION IS,
1. WHERE CAN I BUY A SPEEDOMETER GEAR TO CORRECT THE MPH IN MY TRANS ? I HAVE GONE DOWN TO 60 SERIES 275/60X15 TIRES AND MY SPEEDO IS READING FAST BY 3-4 MPH.
2. WHERE MY SPEEDOMTER cable hooks up to trans. the threaded part that cable hooks to is loose and seaps a little fluid. since i,am gonna be swapping a speedo gear how can i correct this loose problem ? my speedo works good and it being loose doesnt seem to hurt anything but i just want to make it right.
THANKS FOR ALL HELP
BOB
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-28-2009, 01:36 AM   #2
westofb
I really hate wet sanding!
westofb's Avatar
Re: 2 questions on 350 turbos
Here is a link to TCI for the gears....http://www.tciauto.com/Products/Comp...eter_gears.asp
you can find out most answers you have there about transmissions...I think I would buy the threaded piece new and replace it when you replace the gears...snoop around there site some, you will find info how to calculate which gears you need based on tire diameter and rear end ratios. Hope this helps you out!
westofb is offline   Reply With Quote
Old 08-28-2009, 02:05 AM   #3
2tons of fun
go to gm and buy the gear, a good dealer will have them all in stock.
put a new oring around the base of the output when you install the gear.
2tons of fun is offline   Reply With Quote
Old 08-28-2009, 08:50 AM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Bob,
There's a transmission wholesaler place here locally that I picked up the speedo housing, rubber gasket, and the driven gear....If you let me know what exact gears you need and such, I'll go get'em for you and ship to you at cost!....It'll probably all fit in a $4.95 post office priority box
EDIT:....here's the website....https://www.wittrans.com/Default.aspx?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 08-28-2009, 10:18 AM   #5
turp mcspray
turp mcspray's Avatar
I have found that on a th350 (or any other gm trans that uses the small driven gear) 1 tooth of change will = 1/2 of a tenth on your odometer.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-28-2009, 11:50 PM   #6
BCOWANWHEELS
Thanks fellas
