Change the shift-lever on a tilt column
Maybe a dumb question.
Is it easy to change the shift lever on a tilt column? I've done it on a regular column but I'm not sure on the tilt column. Is it as easy? Thanks in advance. Cya, Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb 1974 Chevy Camaro Z28 (Original) ------------------------- The Netherlands |
Re: Change the shift-lever on a tilt column
It is easy to change the lever. It works like the regular shift lever by removing the pin.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thank You!
Cya, Edmond
