Old 08-28-2009, 11:01 AM   #1
Denver64
LS1 conversion Manual Transmission
Hello, I'm in the planning process and am going to start ripping apart my 64 shortbed stepside C10. I'd like to put an LS1 in it but would like to use a manual transmission. Has anyone done this? I'm trying to figure out the best transmission to use and one that will fit well in the cab. Any help would be greatly appreciated.
Denver64 is offline   Reply With Quote
Old 08-29-2009, 01:47 AM   #2
Captainfab
60-66 Nut
Re: LS1 conversion Manual Transmission
I believe a T56 will work as a TKO-500 will also. Board member TR65 has a T56 in his truck and I believe a LS2. Here is a link to one of his threads
http://www.67-72chevytrucks.com/vboa...=1#post2818232
You might try sending him a PM for more info.
BTW welcome to the board
Old 08-30-2009, 12:15 AM   #3
TR65
TR65's Avatar
Hey Denver,
The problem with the T56 (6 speed) is that the shifter is too far back for our trucks. If you have bucket seats you can make it work but not with the bench. I am using a T56 but had to go thru a complicated process of moving the shifter forward 13" in tranny to an inspection port. There is a kit for that and I wrote a thread on that.
http://67-72chevytrucks.com/vboard/s...d.php?t=300892
As CaptainFab says the TKO 500 (5 speed) is a good choice because it is built with three alternative shifter positions. I think the most forward one would put the shifter in about the stock location.
Both need a hydraulic clutch although you can convert to mechanical. Keisler makes a mechanical bell housing for for the LS motors.
http://www.keislerauto.com/index.php
For that matter you can get a Keisler bell housing for the LS and use a mechanical clutch and a traditional manual transmission T10 or whatever. Since they tend to have external shifters the shifter location can be fitted to the truck.
The nice thing about the T56 or TKO is the overdrive gearing so we can cruise at modern highway speeds economically.
Good luck,
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 08-30-2009, 10:18 AM   #4
Denver64
Awesome. Thanks for the info. Yep, I'm definitely looking to have overdrive. Also, the wife has put claim to the truck as "hers" and she wants it to look stock and keep the bench seat. Thus I need to have the shifter in close to the stock location. Thanks again for the info, that's exactly what I was looking for.
