Old 08-28-2009, 08:40 PM   #1
ol Curt
Junior Member
ol Curt's Avatar
Door Panel Screw Removal
I have two screws from my inner door panel that broke off. I have soaked the in penetrating oil and tried to drill them out...broken two bits. I don't know if there is enough left to get an easy out on them...but man they are in there. I'm looking for ideas. I'm thinking of grinding the end off and trying to re-drill. Any ideas?
I also lubed the window hardware, and it rolls very easy till it hits one spot where the window is almost up. Is it difficult to take the things out and clean them up? I suspect the most difficult part is getting the window glass out.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 08-28-2009, 08:54 PM   #2
tommys69/454
1969 short box
tommys69/454's Avatar
Re: Door Panel Screw Removal
grind it flat and use a center drill in a hand drill. these are in regular use in all machine shops and any machine tool supply place. they are sized by numbers and I would say you need a #0. In any case you need to have the pilot smaller than the minor diameter of the thread. then if necessary you will easily be able to use a drill bit.
tommy morehouse
tommys69/454 is offline   Reply With Quote
Old 08-29-2009, 07:40 AM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I had some very rusty ones on a 63 door, head was broken off, I took a small washer, and welded it to what was left of the screw, then took a nut, and welded that to the washer, took a wrench to it , and it came right out.
the heat from the welding is the big thing, it boils out whatever moisture is left in the rust, and expands the bolt, when it cools off it has usually broken fre of the threads, sometimes it helps to squitr a little water on the threads right after you heat it up, this causes it to contract quickly and helps it to break free.
Old 08-29-2009, 10:51 AM   #4
TheDark1
Intentionally Left Blank
TheDark1's Avatar
I had several that I had broken off over the years and I had knocked the square nut off on a few. At the time I didn't have access to a welder, so I used the little plastic nuts that you use for the licence plate in thier place. They just pop in and are still in there years later. If you only need a few on each door, this should work just fine.
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 08-29-2009, 08:58 PM   #5
ol Curt
Junior Member
ol Curt's Avatar
The last method worked best for me! As always thanks for the help guys!!
