![]() Join Date: Nov 2007
67 inline 6 harmonic balancer ?
On a inline 6 250ci, I was going to swap distributor to an HEI. The harmonic balancer doesnt have a bolt so I can turn the engine to #1 cylinder on TDC. It seems to be held by the key, and even the 3 holes for the puller arent threaded. I cant post pics thanks to a lost battery charger. Has anybody else encountered this problem ? Thanks for any help.
72 C20 Longbed 05 1500 Z71 |
Re: 67 inline 6 harmonic balancer ?
turn the flywheel
I am a Referee of life.
Take out #1 plug and hold your finger over the hole while someone bumps it over.When your finger gets blown off the hole you're on #1TDC.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
resident oilfield trash
What he said
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
#5 | |
![]() Join Date: Jul 2007
Clean your timing marks first though and make sure that they are easy to see. I usually pull the distributor cap off and watch the rotor even if I am bringing the engine up on compression with my finger in the #1 spark plug hole. Don't be surprised if it takes several before you get it where you want it. If you have a remote starter button you can bump it over yourself. |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
I just grab the belt and pull the motor over while watching the distributor rotor...
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#7 | ||
Thats gonna suck but I will probly end up doing that. Thanks cdowns
![]() Quote:
Thanks for the responses. I've had this truck in my backyard for almost 3 yrs. and I got alot of work to do !
Six in a row makes it go...
![]() Join Date: Mar 2009
This. The compression is so low I usually just press the belt against the water pump pulley and rotate.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
