![]() Join Date: Nov 2006
Fan clutch going bad who sells the best replacement
WELL TIME FOR A NEW FAN CLUTCH. GM doesnt have them anymore. i went to oreilly's and theres was not all all like the one on my truck but was the replacement for it. i was wondering who you fellas think has the best replacement fan clutch. gonna try napa next i guess.
I BELIEVE IN JOHN 3:16 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Fan clutch going bad who sells the best replacement
It's been a long time, but I have picked them up in junkyards. Look for a late-model full size GM car or truck with a thermostatic clutch unit. Be sure the bolt pattern, shaft length, and fan diameter are correct.
![]() Price should be OK and quality is unbeatable.
well i went to -
NAPA= CHINA & NOTHING LIKE STOCK ADVANCE AUTO= SAME DEAL AUTOZONE= SAME DEAL OREILLY'S= BINGO MADE IN USA, LOOKS JUST LIKE OEM, MADE BY HAYDEN & PART NUMBER HDN 2797 PRICE WAS $44.99 WHICH IS JOBBER AS I HAVE A COMERCIAL ACCOUNT. HOPE THIS HELPS SOMEBODY OUT
sharp as a marble
![]() Join Date: Jan 2007
find an ACDELCO supplier in your town. They sell the thermostatic type for our trucks. this type of fan clutch has a wound spring on the radiator side of the fan clutch. The thermocouple type ( I think ) are all junk. I just looked and saw where you tried Advance. Try them again, and find their commercial accounts parts guy. The guys on the retail counter are usually about a sharp as a marble. Advance in my area is starting to stock ACDELCO.
They are obsoliete from ac delco now. This hayden is identicle to my factory h/d ac delco
sharp as a marble
now it gets tough. IF you could get an ACDELCO catalog that has fan clutches in it, there will be a page that shows specifications. I think that there 2 bolt patterns where the fan clutch bolts to the water pump. maybe try and find a fan clutch with similar specs.
![]() Join Date: Mar 2003
So is your new fan clutch for a 350 or 402 or are they all the same? and how can I tell if mine is bad? Thank you. Dave
BOY DID THAT HAYDEN DO THE TRICK.I,am gonna have to pull that 160 degree thermostat out now because it cools so good. gonna put a 180 degree back in it.
