08-29-2009, 11:53 AM | #1 |
'87 Fuel pump question
I have power delivery issues to the passenger side pump. The switch seems to be "switching" as I got the drivers side to run on either setting by switching plugs. But there is no power at the passenger side plug when the switch is "switched".
Help!!! I need a wiring diagram and couldn't find one by searching. HELP!!! |
08-29-2009, 12:06 PM | #2 |
Re: '87 Fuel pump question
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
08-29-2009, 12:23 PM | #3 |
It doesn't appear to have a wiring diagram for a TBI 2 tank truck just a regular carb. truck.
08-29-2009, 12:52 PM | #4 |
08-29-2009, 01:02 PM | #5 |
08-29-2009, 02:42 PM | #7 |
Best I can tell, other than the obvious, is that the switch in the dash IS bad. I also have removed the passenger tank because the fuel lines and ground were all undone from the top of the tank...things that make you go "oh $hit". I dropped the tank, which turned out to be full of gas, or some terrible smelling brew that weighed about 125#. I got the pump and float assembly out to find that they were completely destroyed from the broken down gas/kerosene junk in the tank. So, I have to have a pump/sending unit assembly, a switch for the dash, and, OH YEAH, a new tank because the stock ones insides are coming apart. AWESOME!!!
08-29-2009, 02:46 PM | #8 |
Oh, and did I mention the damn sky is falling! It was a perfectly clear, sunny sky 20 minutes ago, but now it is raining like he!!...SURE!
08-29-2009, 02:54 PM | #9 |
Robert Olson Transport
try advanced auto parts for the tank print out the thing online and take that to the store its cheaper that way
08-30-2009, 10:15 AM | #10 |
It actually looks like O'Reilly's is the cheapest source for the tank @ $113, but the pump assembly is $250...OUCH!!! I think I am going to slow down on the passenger tank until I finish the 5.3 swap. I will go ahead and get the tank and possibly the float/pump assembly minus the pump and get the correct high pressure pump later.
08-30-2009, 10:39 AM | #11 |
anytime man. glad i could help. i'd wait on the pump since your doing the swap and the sending unit is only around $100 + $80 for the high psi pump you'll be saving money. good time to start piecing together the fuel system for the swap.
08-30-2009, 11:10 AM | #12 |
Next project: 1970 K10
Sending units:
* Dorman p/n 692027 for the driver side, $94 at rockauto.com * Dorman p/n 692044 for the passenger side, $101 at rockauto.com Rock Auto also has the 87 tanks, $110 with shipping to my zip. P/N GM11C, $79.79
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 08-30-2009 at 11:14 AM. |
08-30-2009, 11:22 AM | #13 |
i was just looking for those
08-31-2009, 07:49 AM | #15 |
I got the tank, sending unit, tank selector switch, and even went ahead and got a new A/C Delco pump and sock (I won't be doing my swap until first of year...probably) shipped to my house for less than I could buy the pump assembly locally. Rock Auto...well...Rocks
08-31-2009, 09:18 AM | #16 |
Yes they do, I use them a lot.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
