08-29-2009, 12:14 PM | #1 |
Cab trim
How does the trim that runs around the sides and back of the cab under the rear window stay attached. My Scottsdale never had it and I wanted to put some on.
Sledge Last edited by thump16; 08-29-2009 at 12:15 PM. |
08-29-2009, 01:14 PM | #2 |
Re: Cab trim
can someone help me?
08-29-2009, 02:45 PM | #3 |
yeller
Re: Cab trim
The rear piece slides over clips that are attached to the back of the cab itself, the side pieces then go on, are are bolted on from inside the cab.
It will not be real easy to install the rear clips, as there were studs welded to the back of the cab that the plastic clips attached to. I suggest going to a JY, and taking apart a truck that has this setup...to determine if this is something you can do, or still want to do.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 08-29-2009 at 02:46 PM. |
08-29-2009, 02:53 PM | #4 |
Robert Olson Transport
Re: Cab trim
you can use small rivets for the clips but you have to be very careful marking out the holes and all
08-29-2009, 07:07 PM | #5 |
Re: Cab trim
On second thought. I'll leave em off. I'll go with the lower side trim instead. Thanks guys
Sledge |
