Old 08-29-2009, 01:46 PM   #1
chrislehr
Engine n00b
chrislehr's Avatar
ECE front sway - which bushings go where?
The ones with the zergs on the frame, or on the A arm?
chrislehr is offline   Reply With Quote
Old 08-29-2009, 01:48 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: ECE front sway - which bushings go where?
Greasable ones go on the frame, non-greasable go on the A-arms.
Hart_Rod is offline   Reply With Quote
Old 08-29-2009, 01:58 PM   #3
chrislehr
Engine n00b
chrislehr's Avatar
awesome, thanks for the quick reply. My frame bolts are the opposite way, but I doubt that makes any diff. Thanks!
Old 08-29-2009, 02:24 PM   #4
tcb-1
Nothing to see here.....
tcb-1's Avatar
Rob had to mount the bolts with the threads down because he is running the lowered sway bar towers as well. I believe if you have the standard height towers, you can run them with the threads up.... at least then you don't get roadkill hooked on them...... don't ask how I know!!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 08-29-2009, 02:25 PM   #5
tcb-1
tcb-1's Avatar
......and Chris, your up to a thousand posts!! Congrats!
Doug
Old 08-29-2009, 03:12 PM   #6
chrislehr
Engine n00b
chrislehr's Avatar
Sweet.. Only took over a year, a new engine, and a LOT of how do I do this threads!
Old 08-29-2009, 03:13 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
When we did 72BlckButy's truck,... I noticed his ECE bushings were the same.
(just 2 had grease zerks)
I wonder why they don't make all 4 greaseable?
Keith
Convert to disc brakes.
Old 08-29-2009, 03:19 PM   #8
chrislehr
Engine n00b
chrislehr's Avatar
Im guessing the geometry on the a arm ones mean hardly ANY movement compared to the frame ones.
Old 08-29-2009, 03:50 PM   #9
powell72
powell72's Avatar
I got mine from ECE in '07 and all four of mine are greaseable???
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 08-29-2009, 07:29 PM   #10
tcb-1
tcb-1's Avatar
mine are Energy Suspension urethanes, and they are only greasable on the frame mounted pair.
your just special, Chris!
Doug
Old 08-29-2009, 09:04 PM   #11
ERASER5
ERASER5's Avatar
Mine are the Energy Suspension too. But I just bought 2 sets a AutoZone so all four of mine are greasable.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-30-2009, 09:29 PM   #12
powell72
powell72's Avatar
That's what my mom used to tell me before getting on the bus that wasn't as long as the others when I was a kid.
Chris
