08-29-2009, 02:21 PM | #1 |
wheel adapter
Who sells a quality billet wheel adapter? I know everyone has their own opinion on these things but I just picked up a set of 20’s for $240 (one wheel has a defect in the chrome…still looks fine) Anyway I need to push the wheel out an additional ¾ -1” to make them fit in the rear.
-M.J. 1968 Stepside |
08-29-2009, 02:47 PM | #2 |
67-72 parts collector,…
Re: wheel adapter
I'm subscribing to this,... because I may need a set of spacers/adapters myself.
(I've never been a fan of them,... but I also have a cheap set of wheels I'd like to use) I'd also like to know which ones to avoid. I know there are some that are better than others. Anyone?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-29-2009 at 02:48 PM. |
08-29-2009, 04:10 PM | #3 |
Re: wheel adapter
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
08-29-2009, 05:30 PM | #4 |
Re: wheel adapter
Thanks Wild I appreciate it.
Yes the search button does work... very well in fact if someone was searching “wheel adapters” a thread that is titles “wheel spacer questions” may not come up with-in the firsts five or so pages of search results. All I wanted was a reputable vendor link not a 45 min search to find one.
08-29-2009, 05:42 PM | #5 |
Re: wheel adapter
from wild83c10:
http://www.performancewheel.com/ has anyone tried this company? http://adaptitusa.com/
08-29-2009, 06:55 PM | #6 | |
Re: wheel adapter
Yes I know the names are different, but technically you are looking for spacers. Not trying to give you a hard time, just wish more people would use search. If they did we would have less crap to search through. So a 45 min search could actually only take 15 min.
08-29-2009, 08:02 PM | #7 |
Happy to be here
Re: wheel adapter
Not to pick nits here, but you asked about wheel "adapters", not spacers. Which one are you looking for?
Do the wheels you purchased have the wrong bolt pattern, or incorrect back space?
08-29-2009, 08:27 PM | #8 |
Re: wheel adapter
I am looking for a 1’ adapter 6 lug to 6 lug to correct my backspacing. I would never use a spacer more than about a 1/4” in thickness, besides any thicker of a spacer and you would need longer wheel studs etc. So yes I am looking for a wheel adapter.
08-29-2009, 09:13 PM | #9 |
Re: wheel adapter
Here is the guy I used. Very nice guy to work with and he is the one that makes them when you order. They are not cheap. I ordered them early in the day and called to make sure he got the payment and he was already making them.
http://www.wheeladapter.com/request_...?mode=thankyou
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
08-29-2009, 10:05 PM | #10 |
Re: wheel adapter
That is still a spacer though. You aren't correcting your bolt pattern. A spacer can be made thicker then 1/4" and still be safe. It just uses the existing studs and has another set of studs in it with the same bolt pattern. An adapter would change the bolt pattern from say a 5x5 to a 5x5.75.
08-29-2009, 10:16 PM | #11 |
Re: wheel adapter
My bad…I was always under the impression that a spacer just slipped over your existing wheel studs and an adapter bolted to you existing studs and provided an additional set of studs, regardless of the bolt pattern. Thanks for the information
08-29-2009, 11:05 PM | #12 |
Yellow truck club
Re: wheel adapter
I've got 2.5" spacers that go 5.75 to 5.75 from Ebay for the rear of my truck. 3 years now. Good quality.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
08-31-2009, 01:06 AM | #13 |
3DrDwn--the 'burb not the band
Re: wheel adapter
Got my 2" from Whalen Tire here in Missoula. Of course I was the custom wheel and tire guy there at the time. Don't think anyone there now would even try to look. They came from a company called Wheel 1 Warehouse out of Boise. Not sure on the price as my rep comp'd em to me to get me to try a set of spinners on the 20's they had hooked me up with and were needed to clear the spindle dust cover.
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
09-02-2009, 02:36 AM | #14 |
Superbad
Re: wheel adapter
I've used these guys.
http://www.ezaccessory.com/5_Lug_Ada...rsion_s/44.htm |
09-02-2009, 09:51 AM | #15 | |
Re: wheel adapter
09-04-2009, 01:15 PM | #16 |
Re: wheel adapter
