Old 08-29-2009, 03:32 PM   #1
harrdawg54
harrdawg54's Avatar
How hard would it be....
to swap out my eaton for a dana 70. I am looking at getting this rearend, http://spokane.craigslist.org/pts/1347805106.html I just want to know if it will be a pain or something that can be done fairly easy. thanks.
1969 Chevy K20 Custom Camper
350, 4sp, 33's
High on plans, Low on funds
harrdawg54 is offline   Reply With Quote
Old 08-30-2009, 12:20 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: How hard would it be....
do you have coils?
If so, then you'll need to wld on trailing amr mounts and a panhard bar mount, then deal with the U joint issue.
If you have leafs, then you MIGHT have to relocate/replace the spring mounts and then deal with the u joint.
Then you'd need ford wheels, and you'll want to know the year and model of vehicle so you can get brake parts.
The 3.73 gear is nice though.
Old 08-30-2009, 05:33 PM   #3
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
You wanna put a F**d rear end on a Chevy truck? All your teeth will fall out within the first mile! (and I don't mean the gear teeth either!)
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 08-30-2009, 05:54 PM   #4
Longhorn Man
its a dana rear... ford hasn't built a truck rear in years.
And when they did, it was better then the ones GM built.
Old 08-30-2009, 06:19 PM   #5
Eichorst69
I'd keep the Eaton!
Rob
Eichorst69 is offline   Reply With Quote
Old 08-30-2009, 06:54 PM   #6
Longhorn Man
why? Crappy (no) gear selection, parts are next to impossible to locate, brake drums are junk yard only, brake parts are almost all gone...
The eaton is a disposible piece now. Once something goes bad, replace the whole unit.
