Old 08-29-2009, 05:53 PM   #1
drewfever1020
big block?
who has one in there truck?
what upgrades do i need to do yo put one in?
drewfever1020 is offline   Reply With Quote
Old 08-29-2009, 06:16 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: big block?
I have one? have not drove it yet though so I cant tell you what up grades u neeeed.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-29-2009, 06:30 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: big block?
I've got one, you just need to upgrade your gas card. Cant beat that big block sound.
--Josh
Old 08-29-2009, 07:07 PM   #4
drewfever1020
Re: big block?
so your saying the original harness on my 71 will fit the big block?
and what about my suspension?
Old 08-29-2009, 09:44 PM   #5
1956cameo
1956cameo's Avatar
Re: big block?
I have a couple of big block trucks. The motor mount stands are different on big block trucks. Not sure how different they are and if you have to use them or of small block motor mount stands will work.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 08-30-2009, 12:02 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: big block?
As another member said... you'll be amazed at how much it does NOT drop the nose.
As far as the harness... the starter is in the same location, as is the temp guage sender, distributor, and the alt if you have the right pullies and brackets.
Old 08-30-2009, 10:28 AM   #7
drewfever1020
Re: big block?
ok cool so all really need is engine mounts for a big block right?
Old 08-30-2009, 11:52 AM   #8
STOCKISH
STOCKISH's Avatar
Re: big block?
Pretty much. You might wind up needing a better radiator but I know plenty of people using a stock small block radiator with no issues.
--Josh
Old 08-30-2009, 12:07 PM   #9
drewfever1020
Re: big block?
i have a racing radiator i think it will hold up
