Old 08-29-2009, 08:54 PM   #1
Number21
Number21's Avatar
How do I reattach my shifer?
I just bought a '79 C30 with a SM465, my first manual transmission. I've been teaching myself to drive it...imagine my surprise when the shifter just came right out in my hand in the middle of the road.
So I took the boot off and it looks like there's a little collar on top of the ball at the bottom of the shifter that should keep it in, right? How do I get that collar to seat back where it's supposed to be? Obviously it needs to be pushed down and turned, but I can't get it to turn...
Number21 is offline   Reply With Quote
Old 08-29-2009, 11:43 PM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: How do I reattach my shifer?
channellocks
take this as a chance to pull the shifter (place it in neutral first)
then pull the collar spring and shifter rod completely out...
http://www.pirate4x4.com/tech/billav...465/index.html
check the pivot area for a crack in the spot welds.. use this chance to run a few strong tack welds or an entire bead around the base it will dramatically improve the "slop" in the shifter
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 08-31-2009, 07:26 AM   #3
Keith Seymore
Keith Seymore's Avatar
Yep - just to elaborate a little further, you take the channel locks and grab that collar near the top. Push down while rotating clockwise (I believe) and it should grab and go in. Just like replacing a taillight bulb (...only bigger...).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
