Old 08-29-2009, 11:22 PM   #1
czarcaustic
czarcaustic's Avatar
Trouble when I punch it ...
Hey gang -
I just got my brakes all rebuilt and decided to go for a little spin in my new toy. It took me a little while to get her started, but when I did things seemed to be tooling along just fine. When I went to put it in gear and pull out of the garage ... stall. Repeat x 10.
I took the inline fuel filter out of the line from the fuel pump to the carb - and it was ridiculous. I went over to napa and got me a fresh filter. Popped it in and she fired right up and started to move. I was really feeling accomplished at this point. Until I got out on an abandoned stretch of road and punched the accelerator and it bogged down and almost stalled. I can add throttle slowly and it will pick up speed just fine, but if I try to pour it on too fast - no can do.
Any suggestions for a newbie like me? Am I going to have to learn how to rebuild a carburetor or does this sound like something you have heard of before?
'71 GMC 1500 Longbed (Marilyn: PICS)
'04 Toyota Tacoma (grocery getter)
'03 Lexus ES 300 (Wife's)
'72 GMC Short Fleet (Sold - offer I couldn't refuse)
czarcaustic is offline   Reply With Quote
Old 08-29-2009, 11:27 PM   #2
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Re: Trouble when I punch it ...
here are a few places to start.....check your timing. and check yuor carb adjustment. how do your plugs look? is the gas new?
just a few things to consider.
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 08-30-2009, 03:27 AM   #3
dirtboy488
dirtboy488's Avatar
Did you check that filter again? May have lines that are rotting or a bunch of deposits in the tank that decided to break free. Also did you do anything with the booster? Maybie there is a vacume leak now?
1969 C10 swb 2wd
1970 C10 swb 2wd SOLD
dirtboy488 is offline   Reply With Quote
Old 08-30-2009, 05:13 AM   #4
mikey531
mikey531's Avatar
dirtboy488 beat me too it I was going to suggest vacuum leak
mikey531 is offline   Reply With Quote
Old 08-30-2009, 08:13 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
A few more details about the truck may also help get you pointed in the right direction.
Did the truck set up for a long time?
Has the tank been cleaned?
Have you checked the "sock" on the fuel pick-up in the tank?
As stated above,are all vac lines hooked up or plugged?
Is the vacuum advance working or maybe leaking air thru a bad diaphram?
Just some initial thing to look over and think about.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-30-2009, 08:23 AM   #6
geezer#99
geezer#99's Avatar
I agree. More details. What kind of carb. Fuel pump? Stock or electric.
Sounds like fuel related issue.
Old 08-30-2009, 11:17 AM   #7
czarcaustic
Thanks for the suggestions guys ... I will check each one.
It is a 350sb from 1980 that was placed in the GMC. The truck sat for a good 5 years prior to me purchasing it. There is no power brake booster, so I don't think there would be a vacuum leak associated wit that.
However - the tank has not been cleaned. There seemed to be about a 1/8 of a tank of fuel in the tank when I bought the truck and I put some SeaFoam in the tank as well as about 1/2 a tank of fresh gas.
The truck has a manual fuel pump that is working great - so I am guessing it is either a problem with the quality of the fuel or a carburation issue.
I am guessing that I should probably learn how to clean a gas tank.
Old 08-30-2009, 01:29 PM   #8
geezer#99
geezer#99's Avatar
Still wondering what kind of carb. Maybe quadrejet 4 barrel. Quadrejets had a filter inside the fuel inlet. Could be still there and plugged.
To fast of an opening on a secondary air valve on a quadrejet can cause a huge bog too. Let us know about the carb.
Old 08-30-2009, 03:21 PM   #9
czarcaustic
I am actually unsure of what kind of carb it is. I will take some pictures this afternoon when I get down to the garage and post them later.
Old 08-30-2009, 10:23 PM   #10
kyfig70c20
Similar thing happened to me this weekend;
driving down the road when it just seems like I run out of gas. I knew I wasn't out but pulled in the gas station and put a few gallons in. Start up and start back home and the same thing happens. I tow it home but I can tell it just isn't getting fuel. I replaced th inline filter a couple of weeks ago. Do I start at the tank and work forward or change the pump? What is the easiest way to get to the sending unit/sock pick-up. This truck sat for several years and I just recently started driving again. It has run strong and the problem came on all of a sudden with no indication anything was going on.
kyfig70c20 is offline   Reply With Quote
Old 08-30-2009, 11:03 PM   #11
tecky11
Since they sat for a while I would rebuiild the carb
tecky11 is offline   Reply With Quote
