08-30-2009, 02:06 AM | #1 |
Ignition lock help
Hi all,
I have a 1978 Chevy pickup and I need to replace the ignition lock on the column. I have the column completely taken apart, but I cannot get the cylinder out. All the resources I have found show a screw underneath the turn signal assembly but this truck has no screw anywhere near the cylinder, either above or below. Its a 4x4 and automatic. Can anyone help? Thanks! Colby. |
08-30-2009, 07:30 AM | #2 |
One shot, one kill.
Re: Ignition lock help
34, there is supposed to be a screw in there, should be a torx head. If not, someone may have changed the colunm with an earlier one. In that case look for a slot that would be near where the cylinder would end. The slot is about 1/2" long and 1/8" wide. It may be filled or covered with a very thin cast in plastic cover in the recess. Use a flat blade screw driver and with your hand punch thru it. Then push down, that will release the cylinder. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
08-30-2009, 10:52 AM | #3 |
Robert Olson Transport
some of them had a clip in the column as opposed to the screw but its in the same general area
08-30-2009, 11:50 AM | #4 |
Yo! Been there! Try this link:
http://www.nastyz28.com/forum/showth...switch+removal It will even give you a pic of where GM hides the release for the lock cylinder. Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
