Old 08-30-2009, 10:09 AM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Aftermarket part #s care to contribute?
Power brake unit 1963-66 Chevrolet C10
http://cardone.com/English/club/memb...ARTNUM=50-3537
Old 08-30-2009, 02:48 PM   #2
mbgmike
Re: Aftermarket part #s care to contribute?
We sell A1 Cardone products. What are you asking?
mbgmike is offline   Reply With Quote
Old 08-30-2009, 08:22 PM   #3
aerotruk63
aerotruk63's Avatar
Thought of a forum for part #s that still exist!
Old 08-30-2009, 08:31 PM   #4
scotts62
One day...
scotts62's Avatar
Like original or just aftermarket stuff being tracked down?
Scott
93 crew cab build
Project 62
Old 08-30-2009, 08:34 PM   #5
aerotruk63
aerotruk63's Avatar
Parts you can order to replace originals.Wagner,Standard,Autoline,etc.
Old 08-30-2009, 11:03 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Well here's one - for the 1960 GMC (and possibly Chevy) with the OEM AC GF-62-C under floor spin on cartridge fuel filter - the Napa part number is 3271 for the filter element. This replaces AC GF-157 cartridge.
Also the replacement stop light switch number is Napa Echlin SL 169.
Old 08-31-2009, 06:54 AM   #7
63 & 64 Bowties
and a few others
I see what you're doing now. Neat idea. At first I thought, shouldn't this be in the parts section? But now I get it.
Napa has a bunch of old vehicle parts that others don't. I had a 66 International pickup a few years back, and I was amazed that I could get a bunch of parts right over the counter for it at Napa.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 08-31-2009, 06:00 PM   #8
mbgmike
We sell parts from most all manufacturers new and reman. If you have a specific part or part cross reference to another brand we can look it up. We have the same part systems that NAPA or any other retail Auto part store use.
I can post part numbers on some if you would like but If you have some ones in mind just let us know.
We offer the same parts as NAPA or any quality auto parts store. Plus we have suspension parts made for Obsolete cars which you can't do at NAPA.
Old 08-31-2009, 06:26 PM   #9
MacAttack
283 Drama Queen
MacAttack's Avatar
www.bumpandgrindgarage.com (Wow, I had no idea).
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 08-31-2009, 06:36 PM   #10
mbgmike
Here are some Delco and TImken on brake parts. This could take years
DELCO
18E1020 LS FRONT WHEEL CYLINDER
18E573 RS FRONT WHEEL CYLINDER
18E1123 LS REAR WHEEL CYLINDER
18E1124 RS REAR WHEEL CYLINDER
18J1746 REAR BRAKE HOSE 115 WB
18J1747 REAR BRAKE HOSE 127 WB
18K1596 FRONT DRUM BRAKE HDW KIT LS/RS
18K503 FRONT DRUM BRAKE ADJ SCREW
18K1597 REAR DRUM BRAKE HDW KIT LS/RS
18P2213 BRAKE CABLE 91.7/8”
18P2214 BRAKE CABLE 80.3/8”
18PG1138 BENDIX MASTER CYLINDER PB
A1 CARDONE
10-34404 DUAL MASTER CYLINDER REMAN 1.1/8” BORE
10-40000 MASTER CYLINDER REMAN 1” BORE
TIMKEN
SET2 FRT WHEEL BEARING OUTER
SET5 FRT WHEEL BEARING INNER
90155 SEAL
18620 REAR WHEEL BEARING CUP SPICER 60
18690 REAR WHEEL BEARING CONE SPICER 60
6408 REAR WHEEL BEARING LEAF SPRINGS
450067 REAR WHEEL SEAL LEAF SPRINGS
455860 REAR WHEEL SEAL COIL SPRINGS
Sorry we have pics but I don't know if I can post them here cause they are mfg pics
Old 08-31-2009, 06:38 PM   #11
mbgmike
Mac.
We just have to try harder than the big stores
Old 08-31-2009, 07:02 PM   #12
mbgmike
Some more
ac delco
45a0045 ls tie rod end
45a0058 rs tie rod end
45a6001 tie rod adj sleeve
45a6003 tie rod adj sleeve
45c1001 idler arm
45g0502 sway bar bushing
45d2007 lower ball joint
45d2008 upper ball joint
45j0003 upper control arm shaft kit
45j0017 lower control arm shaft kit
36-350390 power steering rebuild kit 2 mt pads
36-351380 power steering rebuild kit 1 mt pad
45h0011 front coil spring
45h2011 rear coil spring
45h3018 rear coil spring
45g15325 leaf spring bushing
45g16051 leaf spring bolt
moog
es350l tie rod end ls
es370r tie rod end rs
k6086 pitman arm
k0698 upper control arm kit
k6147 lower control arm kit
sb253 rear leaf spring bushing
