Old 08-30-2009, 06:28 PM   #1
Pont406
heat sux!
It's 106 in a shades right now. I went for a short drive. I replaced complete cooling system but today it was running hot again at 190. Before was 175 and 180 at 3500 rpm on the freeway. I will try straight water later on. I took a pic of the smoke from the fire that is going on right now. Air is bad, I could feel a slight power loss. I need to get a/c for my c10 one day. My back was stuck to the seat. Heat is sux.
Pont406 is offline   Reply With Quote
Old 08-30-2009, 06:41 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: heat sux!
190 isn't hot, I wouldn't worry about it. My 350 always runs at 190.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-30-2009, 06:48 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: heat sux!
190 is where it should be
Old 08-30-2009, 06:59 PM   #4
Pont406
Re: heat sux!
I didn't try the freeway but I am sure it will be around 210. I did change converters and I think a new converter causing it to run hot and slightlly less mpg.
Old 08-30-2009, 08:41 PM   #5
Boog
laying low
Boog's Avatar
Re: heat sux!
[I replaced complete cooling system but today it was running hot again at 190. Before was 175 and 180 at 3500 rpm on the freeway]
If it will run those temps at 3500 rpm on the freeway you do not have a cooling problem! 190 with 106* ambient temp ain't bad either.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-30-2009, 10:18 PM   #6
QKENUF4U
QKENUF4U's Avatar
Re: heat sux!
straight water isnt a good idea.... so ya understand anti-freeze (coolant) raises the boiling point (along with the cap) so running straight water will lower boiling point and yoy may run hotter/overheat real quick (remember 212* is boiling on reg. water)
so run watter wetter or coolant... also whats your thermostat rated at ?? 190* aint nothing to worry about...
QKENUF4U is offline   Reply With Quote
Old 08-30-2009, 10:47 PM   #7
2tons of fun
Re: heat sux!
is it a stall or a stock cinverter?
i have seen stalls overload the tranny cooler and thusly heat the radiator causing higher water temps.
190 aint bad though, you never did say what your tstat was either.
2tons of fun is offline   Reply With Quote
Old 08-30-2009, 11:01 PM   #8
Pont406
Re: heat sux!
I am running a gutted t-stat. After trying 2 mr gasket high flow t-stat with bad results. Both failed and I had to tow it. Temp went to 240.
I have a stand alone aux trans cooler. Once the heat goes down I will swap converters again. TCI 11 inch converter rated at 2500 and stalls at 2900.
Old 08-30-2009, 11:06 PM   #9
Longhorn Man
Re: heat sux!
water cools better than coolant.
Antifreeze only ups the boiling point a few degrees... to 223 without added pressure from the cap.
Water boils at 212 F at sea level pressure, but when you increase the pressure, it raises the boiling point. For every one pound increase in pressure, you raise the boiling point about 3 1/2 degrees (at sea level) So with the typical 13 pound rad cap, this increases the boiling point 42.25 degrees... or 254.25 degrees.
Old 08-30-2009, 11:08 PM   #10
Longhorn Man
Re: heat sux!
pont... i would add a normal parts store T stat before swapping out the converter. Mr Gasket builds junk.
Old 08-30-2009, 11:15 PM   #11
Pont406
Re: heat sux!
When I took it back they didn't ask any questions and gave the money back. It is junk. My cowerker had one go bad also. No more mr gasket parts for me.
