![]() Join Date: Jun 2007
Tilt column question
I installed a tilt column in my Jimmy today. Everything went pretty well considering I was doing it myself. As I was finishing up I installed the steering wheel. There is a 3/16 inch gap between the back of the wheel and the column, is this normal? Everything works, horn, directional and hazards, shift indicator light, and the indicator is correctly lined up with the correct gear. The only issue is that space?
Thanks Mark |
![]() Join Date: Apr 2005
Re: Tilt column question
That's probably within tolerance. Is it an aftermarket wheel? Sometimes the adapters aren't that good. Did you try tightening the wheel nut down more? Just some thoughts.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 08-30-2009 at 07:12 PM. |
#3 | |
Mark |
