1970 Daily Driver
Heater Core Supply?
It is the hose coming from the water pump that supplies the heater core with hot water right? I am putting a shut off valve in and don't want it to be on the wrong line allowing hot water into the core when I am using my a/c. Thanks
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 08-30-2009 at 11:23 PM. |
1970 Daily Driver
Re: Heater Core Supply?
I just looked at the Vintage air online diagrams and it says to put the valve on the intake manifold side hose and not the water pump side. I am glad I looked at the diagram first, I thought it would be the water pump side for sure.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
![]() Join Date: Jul 2004
I'll just verify for you, the water comes out of the intake, the same passage that goes to the thermostat and OUT to the radiator, the intake side uses the small 5/8 line and the 3/4 return goes to the pump.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
