HEI... go do it right now... careful though...
I just spent the day installing my HEI, I stole it off of my 78 Malibu wagon.....running the wire was the hardest part. Also I leaned against my heater hose and busted the dang heater core! So be careful about that........
Then when I got done it just cranked and cranked, so I thought I screwed up.... sat there thinking and realized I never plugged in the cap! Plugged it in and Whammo it started instantly! Ran it around in the desert, went out on the highway, turned it off and on a dozen times. It starts much better, and the all the hesitation is gone. Can't wait to see how the mileage improves. So Go Do It NOW!!!! you won't be sorry....!
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban ![]() Endeavor to persevere. "All of a sudden, I'm the old timer!" Some old timer on American Pickers. |
SPARK O MATIC
10-4 That is the best upgrade a guy or gal can do to these ol Chevy's in my book especially for the $$$
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
newly minted old timer
absolutly. even for the guys like me who like the original type trucks. its one upgrade that everyone should do. points are a pain in the ass...
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
Half a bubble off!
I totally agree! Mine has been on for 3 years, and I would never consider having points on any motor again.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
![]() Join Date: Dec 2002
have a qualified HEO didtributor rebuild shop set the centrifugal advance curves for the engine it is installed in... There is a wide difference among advance curves.. and also check the vacumm advance to be sure total advance is within specs...
....And.... set the spark plug gap at .045 ( I have the advance curve info as contained in GM/AC Delco Tune Specs., manual SD-100...This manual gives tune-up specs 1971-1980. I specifically like the specs that state the total advance (centrifugal & vacuum) @ 2000 RPM....If you have the proper timing lite; makes it super easy to set timing ............Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
14.1 @ 96MPH
Indeed. I went HEI and will -never- go back. The improvement over a points setup is just sick.
Project1970 - LS1 Swap Complete! ![]() |
I finally got an avatar
Definitely one of the best things you can do. Once I got the dead module sorted out my HEI kicks the *stuff* outta points.
And I've broke that bottom hose off the heater core 3x. ARRRRRRGH ![]()
-72 C-10 short step (straight line only) 12.922/102.28 -69 C-20 on Propane (DD) -69 C-10 -56 Mack B-753LS (tow rig) -94 Chev K2500 Short Ex-Cab -89 Isuzu Trooper...Kinda -03 Kawasaki KFX-400 -05 Suzuki DRZ-400S Last edited by '72 Shorty; 01-13-2003 at 06:17 PM. |
Formerly yellow72custom
I agree with everyone else, HEI kicks a$$. Been in my truck for 2 years and 20,000 miles with zero problems.
Did anyone else notice that a points-equipped SBC sounds about twice as loud through the exhaust at idle as a HEI equpped SBC? Why is this?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
http://public.fotki.com/street
Ok Im sold, but the question have is will a HEI from a 250 6 cyl fit in my 230 CID
I like my HEI also; does anyone have trouble with their HEI cap rubbing against the firewall? 71 Blazer 350/th350.
Out of the carpool lane.
Our64, yes it will.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
