Old 08-30-2009, 09:54 PM   #1
JQE80
73-80 bumpers on 81-87 frame?
First off where is the search thats normally above the posts at? I can't find the tab to click on that says search this forum? OK my question is that I am in the process of switching my 79 over to an 87 or so frame, I know the front of the frame is different so how do I go about mounting up some older bumpers to the newer frame?
Jarrid
79 c-10
big 10
JQE80 is offline   Reply With Quote
Old 08-30-2009, 10:23 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 73-80 bumpers on 81-87 frame?
Search has been disabled for now. You will need to cut off a set of 73-80 frame rails, or modify your 81-87 rails. The difference in shape won't allow the bumpers to swap with out some frame mods.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-30-2009, 10:30 PM   #3
JQE80
Yeah I know the older ones are rounded and the newer are kinda diagonal. Just was hoping to get some step by step or a guide from someone that has done this. Can I just cut the newer style frame so that it is shaped like the old style or is the best way to cut off the rounded style and weld them onto my 87 frame?
79 c-10
big 10
Old 09-01-2009, 11:49 PM   #4
JQE80
anyone have any more info?
Jarrid
79 c-10
big 10
Old 09-02-2009, 12:12 AM   #5
Mtrhd329
Back when i was 15 I got an 85 junkyard bumper to fit my 79. Not sure if it was supposed to work but i used to brackets that i got with the newer bumper because my old brackets wouldnt fit.
Mtrhd329 is offline   Reply With Quote
Old 09-02-2009, 12:15 AM   #6
JQE80
Well I am trying to do the opposite of that but I do have my old front brackets and bumper so maybe I will play around with that.
Jarrid
79 c-10
big 10
Old 09-02-2009, 11:22 AM   #7
454HO
I am wanting to do the same thing, put a 73-80 bumper on an 86 frame. I have the correct bumper brackets, but I have not found a suitable bumper yet.
- Greg
454HO is offline   Reply With Quote
Old 09-02-2009, 06:17 PM   #8
JQE80
Is that all it takes? Just the old bumper brackets for the newer frame? I have took the bumper and brackets right off my 79 frame so should it bolt on to the newer style frame then?
Jarrid
79 c-10
big 10
Old 09-02-2009, 06:36 PM   #9
454HO
Jarrid
I did not mean to imply that. I don't have a bumper to try it. But I know that to go the other way you only need to trim the top part of the frame a bit.
- Greg
