Old 08-30-2009, 11:27 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
How hard is it?
How hard is it to swap a SM465 for a M22? 66 1/2t LWB 350. Driveshaft? Crossmember? Etc Etc
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-31-2009, 12:56 AM   #2
Eagar1
Re: How hard is it?
I am not sure the input shaft has the same number of teeth or even if the M22 will bolt up to that bell housing, and I don't know if any other trans that came in the truck had the same length or output shaft, so it will be interesting to hear from others what it will take.
My guess its a bear cause you will need to change bell housing, clutch, linkage, shifter, crossmember fab, special driveshaft, etc. so..... if you are going to use it as a truck keep the granny gear, if you are gonna just cruise it then its worth it to go with the M22 they are very strong and should handle a hopped up small block or even a mild Big Block.
Eagar1 is offline   Reply With Quote
Old 08-31-2009, 01:23 PM   #3
19GMC63
19GMC63's Avatar
Re: How hard is it?
you could probably use your bellhousing, but the M22 probably has a smaller bearing retainer than the SM465. You would have to have a ring machined in the bellhousing opening, or there may be a larger aftermarket bearing retainer for the M22... I don't know. Either way, this would allow to keep your stock linkage then you would swap the 10 spline clutch disc for a 26 spline one.
The SM465 uses a fixed yoke, M22 uses a 32 spline slip yoke, so that's something to remember.
The SM465 only uses the bellhousing mounts and not a rear one... the M22 probably does.
If you are going to go through this trouble, I would probably go ahead and find something with overdrive for cruisability.
19GMC63 is offline   Reply With Quote
Old 08-31-2009, 01:41 PM   #4
Jimmy S.
Re: How hard is it?
I would try to find a new process made MY6 trans. Four speed.fourth being overdrive.
Jimmy S. is offline   Reply With Quote
Old 09-01-2009, 10:11 AM   #5
thirdstreettito
Resident of Here
Re: How hard is it?
Thanks guys, I'll see if I can eventually put a M22 in.
~Bradley~
Miss having a truck
