Old 08-30-2009, 11:29 PM   #1
into69z
"brand new second-hand"
into69z's Avatar
trouble with a wobbling wheel
I was coming home the other day when a guy commented on a great truck then told me that the rear wheel was wobbling on the passenger side. I had my wife drive the truck and I followed to see the problem and the wheel looked like it was bent , so I swapped the front for the back and the back rim I put up front was straight and true but the front one I put on the back was now wobbling. The wheels are the 2008 2500 HD wheels and should be perfect as they had only 50 miles or so on them. I guess the axle is bent or maybe the bearing is worn out....has anyone gone thru this before and what kind of problems did you have? Te rearend is out of a 1986 3/4 T(non floater type 14 bolt).....any help would be great
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 08-31-2009, 12:01 AM   #2
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Re: trouble with a wobbling wheel
is your wheel mounting flush to the drm, is the drum on straight? assuming you have drum brakes.
and yea check the axle for play. could be a number of things.
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 08-31-2009, 12:14 AM   #3
Paul M
Junior Member
Paul M's Avatar
possibly a bent flange on the axle itself,i had that issue with my tahoe. jack it up take off the drum and spin other tire, watch flange to see if its running out
67-72 Truckless for the moment
Member# 1126
The one that got away http://customclassictrucks.com/featu...001/index.html
Paul M is offline   Reply With Quote
Old 08-31-2009, 12:40 AM   #4
dan42
dan42's Avatar
Maybe a wheel bearing -
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 08-31-2009, 12:57 AM   #5
Daves72'GMC
Smile Re: trouble with a wobbling wheel
Jack the truck up in the air with the rear wheels off the ground and exchange the rr for the Lr and put it in drive and see if it is still wobbling.You can go to some tire stores and they can check the straightness of you rims.Goodluck.
Daves72'GMC is offline   Reply With Quote
Old 08-31-2009, 12:59 AM   #6
2tons of fun
a wheel bearing wouldnt make a wheel wobble, it would lean, slightly.
you need to make sure that the wheel is fully seating againt the drum. measure the opening in the wheel and the step in the axle shaft to make sure the wheel is fitting over it a not pinching aginst it. mark the first lug nut you tighten and see if it is the deepest portion of the wobble.
2tons of fun is offline   Reply With Quote
Old 09-01-2009, 11:38 AM   #7
clear
I had this exact problem when I bought my truck. I tore apart the rear end and discovered the Axle was bent along with the bearing being destroyed. Replaced the axle and bearings, also a bent axle makes it a ***** to get the C-clip off. Oh yea while you are in there replace the drums with disc brakes since it will be the perfect time to do so.
clear is offline   Reply With Quote
Old 09-01-2009, 11:54 AM   #8
rwolf9653
more ideas than money
rwolf9653's Avatar
My dime is on a bent axle. Second would be bearings.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 09-01-2009, 03:40 PM   #9
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Yep, I say bent Axle. My dads 99 burb did this. I pointed it out to him and said bent axle. He had a new axle shaft put in and now it is fine.
He fish tailed it around a u-turn and smaked a curb and that is how it happened. He tells me after I pointed it out.
LOW DOUGH is offline   Reply With Quote
Old 09-01-2009, 11:55 PM   #10
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
My crystal ball says bent axle.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
