hole on side of block?
i have a 454 bigblock and i was wondering what are the 3 holes on each side of the block? they are capped or closed with some sort of cap!
350 small blocks also have them? are they replaceable? |
Just Not Low Enough!
Re: hole on side of block?
they are called freeze plugs, and yes they are replaeable.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd ![]() Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
were can i get them?
![]() ![]() Join Date: Dec 1999
Any auto parts store. They sell them as kits for engines. Or you can buy them individually.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
ok cool thanks alot
if they're not rusted out or leaking they're better off left alone
I agree.Is the motor in a vehicle?There are other freeze plugs on the front and back.
Yep what they said!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
the motor is on a stand and its missing two plugs so im just gonna get those two that i need!
Active Member
![]() Join Date: Jul 2007
Since this is the first time you've done this, order an extra one. They're cheap. Also, they are an extremely tight fit to prevent coolant from leaking out. I've used a small amount of high heat sealant around them before, but it's not necessary if the surfaces are clean and smooth.
Also, you will need some tool that you can use to insure they go in evenly... That's where the extra one may come in if you bugger one up... |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'd be very leery of an engine missing the block plugs. Why are they gone ? If the engine had straight water in it and freezing made them pop there is a high chance the block itself is cracked.
As far as installing them, just use a socket that fits snugly in the recess and tap them in with a hammer. Nothing to it.
