Old 08-31-2009, 09:15 AM   #1
Drop Jaw Kustoms
'63 suspension on a '62
will it work? im new to the 62
Drop Jaw Kustoms is offline   Reply With Quote
Old 08-31-2009, 09:17 AM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: '63 suspension on a '62
Sure...change out the crossmember, and redrill some holes.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-31-2009, 09:20 AM   #3
Drop Jaw Kustoms
thanks for the fast answer chief..i've built a 64 before but never a 63 so i was just needing to know this cus all the parts are 63&up
Old 08-31-2009, 10:24 AM   #4
joe231
joe231's Avatar
While doing the swap you should go ahead and step up to the 73-up front crossmember with discs....
CHEVY ONLY
Old 08-31-2009, 12:09 PM   #5
Drop Jaw Kustoms
is it the same proccess as the 64 swap cus if it is i rather go that route.....i just finished pulling the crossmember so i gotta decide so i could get that thing rolling again....
Old 08-31-2009, 01:18 PM   #6
joe231
joe231's Avatar
Yes it is
'63-66 frames are all the same
CHEVY ONLY
Old 08-31-2009, 06:09 PM   #7
Drop Jaw Kustoms
thanks joe231 for the help
Old 08-31-2009, 06:13 PM   #8
joe231
joe231's Avatar
no problem and good luck!!!
post pics if you can
oh and
CHEVY ONLY
Old 08-31-2009, 06:16 PM   #9
Drop Jaw Kustoms
ohh i will once i get started on the swap
oh yeah i sort of forgot to introduce myself....but hello to everyone if its not too late
Old 09-01-2009, 12:51 AM   #10
Captainfab
60-66 Nut
Yeah, if you're going to all that work why not upgrade to discs?
Old 09-01-2009, 08:33 AM   #11
joe231
joe231's Avatar
I think I miss-read your post, the 60-62 frames are different, but I believe all you have to do to swap in a newer cross member is drill some extra holes on the 60-62's
CHEVY ONLY
Old 09-01-2009, 09:35 AM   #12
Drop Jaw Kustoms
yea i was at a friends shop yesterday and he has a 74 crossmember with disc brakes and i could get it at a good deal on it so i was wondering if the 62 frame is narower because of the torison bar suspension or if its the same width....
Old 09-01-2009, 09:47 AM   #13
joe231
joe231's Avatar
The frames are close enough that it will work
several on here have done it
you can even get aftermarket 6 lug rotors that fit the 73-up, if you don't want to swap the rear end
CHEVY ONLY
Old 09-01-2009, 10:56 AM   #14
Drop Jaw Kustoms
yea im planning on keeping the 12 bolt but i was reading on another thread that some spacers had to be put between the crossmember and frame
Old 09-01-2009, 12:08 PM   #15
joe231
joe231's Avatar
yeah it is like anything else, take it with a grain of salt
I have heard many more people say they had no problem bolting it up than the ones saying they used spacers.
the frame will also flex some, so I wouldn't be too worried about a 1/4-3/8 of an inch difference...that is just me
on our '66 with a mid 80's cross member, when I pulled the cross member loose the frame kinda sprang out a bit...seems to be the same as most everything on these trucks...there were allowable tolerances from the factory.....no factory vehicles are perfectly the same
CHEVY ONLY
Old 09-01-2009, 01:53 PM   #16
Drop Jaw Kustoms
Thanks for the info im gonna be heading out to my buddys shop today so ill get some measurements and maybe pick it up if its close
