Old 08-31-2009, 12:54 PM   #1
AJs72K5
AJs72K5's Avatar
Radiator Dimensions
I sold my old radiator with the intentions of getting a drop in aluminum replacement from these guys --> link
However, looking thru my new summit racing catalog, BeCool has a new universal line with GM style inlet and outlets. Only problem is, I don't know that actual length and height measurements, since I sold mine already Can anyone help? Not looking for core dimensions, but physical length and height.
Thanks.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 08-31-2009, 02:13 PM   #2
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: Radiator Dimensions
Seems most of the aftermarket one's I see going in are 19x31. My original one was 19x33, but the replacement worked great.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 08-31-2009, 08:18 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
My replacement 4 core measures about 33 wide by 18 tall and is about 2 1/2" thick.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-31-2009, 08:48 PM   #4
jaros44sr
jaros44sr's Avatar
Be careful with that lower water outlet neck, had a heck of a time getting alignment right, mine was strait, but yours looks like it angles up and maybe of help. Good luck to you, as always, you know the drill, post up pics
Using stock four core brackets was also a challenge b/c alum. rads are squared and factory are more rounded at the seam where the brackets sit
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-01-2009, 10:13 AM   #5
Burt4x4
Burt4x4's Avatar
I think the radiator "size" is 27", that is just the core measurment not including the "tanks". When I ordered my dual fan & shroud setup from Flex-a-lite I ordered the one for 27" GM Radiators...
My clubs site is down so I cannot post up pics
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-04-2009, 07:07 AM   #6
clos69
Its Topless Season!!!!
clos69's Avatar
AJ....I just saw this thread...I 'll get you the exact dimensions later on today since it's your old rad.Carlos
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 09-04-2009, 09:07 AM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Now wait... did you want the measurments of the existing radiator or the BeCool? I have a 1000hp BeCool which I can measure if you want.
Tom Vogel is offline   Reply With Quote
Old 09-04-2009, 09:47 AM   #8
AJs72K5
AJs72K5's Avatar
Wanted the dimensions of the old rad to use as a starting point for the new one.
- AJ
Old 09-04-2009, 11:33 PM   #9
clos69
clos69's Avatar
AJ ..the rad measures 34Lx19Hx 3 1/4 where the brackets mount...hope this helps
-Carlos-
The of America
Old 09-04-2009, 11:36 PM   #10
AJs72K5
AJs72K5's Avatar
Thanks Carlos.
- AJ
