Old 08-31-2009, 01:23 PM   #1
69_C10
Doing it my damn self.....
69_C10's Avatar
Help on differential please...
Hey guys,
I have a question for my friends out here. I have a 12-bolt in my truck and, it's also a posi. What I don't know is what gear ratio it is. Since there really isn't marking to tell me, what is the best way to get the gear ratio?
Thanks everyone,
Mark Ingle - Asheville, NC
Mark...
Project 69 Stepside...http://67-72chevytrucks.com/vboard/s...d.php?t=290761
69 C10 Stepper - Current Build
94 Silverado - Driver
05 Hummer H2 - Unique Whip
69_C10 is offline   Reply With Quote
Old 08-31-2009, 02:02 PM   #2
C10Slim
Re: Help on differential please...
You can remove the differential cover and count the number of teeth on the gears, but that can get messy.
Poor mans version: You can also jack up the rear put it in neutral. Use chalk to mark the tires and ground so you have starting point also mark the drive shaft to the frame or rear end. While rotating the wheels 1 full turn count how many times the drive shaft rotates. So 3 full turns and a almost a quarter would equal like 3.23 gear. It's not super accurate but would put you in the ball park.
C10Slim is offline   Reply With Quote
Old 08-31-2009, 02:05 PM   #3
69_C10
69_C10's Avatar
Hey, poor mans version is the only way I can roll. Thanks for the reply. I'll give it a try.
Mark...
Old 08-31-2009, 07:51 PM   #4
LONGHAIR
The numbers (tooth count) are stamped on the edge of the ring gear. Pull the cover off, spin the gear around (while wiping the lube out of the way) and you will find the numbers. It will be two 2-digit numbers seperated by a dash. 41-10, 41-11, 41-12, 40-13, etc. Divide the smaller number into the bigger.
41-10= 4.10
41-11=3.73
41-12=3.42
40-13=3.07
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
