Old 08-31-2009, 03:08 PM   #1
pat386
misshape grape
pat386's Avatar
rear end question
just got a great deal ona set of 20x8.5" coys.. the fronts are about fine, but the rears sit about 3" too far in. I was told my truck has a suburban rearend, but I can't confirm that. Is it normal on a 83 swb for the rears to sit in? I don't know if 3" spacers are the best idea to use, not sure if they are safe or not so I'm trying to see what my options are.
So basically, is it normal for the rear wheels to sit that far in? or does my mutt have a different rear axle in it? thanks!
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did..
pat386 is offline   Reply With Quote
Old 08-31-2009, 03:54 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: rear end question
the front has a wider track than the rear from the factory
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-31-2009, 04:02 PM   #3
pat386
misshape grape
pat386's Avatar
ok, thanks!
anybody know where to get wheel spacers?
Old 08-31-2009, 04:20 PM   #4
lowchevytrucks8503
sounds to me they got the offset wrong.... they will be different from front to back. If you got them new I'd talk to coys about the problem. IMO 3 inch spacers would be a bad idea.
lowchevytrucks8503 is offline   Reply With Quote
Old 08-31-2009, 04:22 PM   #5
bigbadjohn84
88-98 fullsize rearend will solve the width issue. that or send the wheels back for differnet offset.
bigbadjohn84 is offline   Reply With Quote
Old 08-31-2009, 06:21 PM   #6
Primer70
Superbad
Primer70's Avatar
I had the same issues with my Suburban. I used some 1.5" wheel spacers on my rear wheels. They've been on there for a year & a half with no problems. I will be going to 22s in the rear later with an offset that will make it so I don't need wheel spacers.
These are the ones I used: http://www.ezaccessory.com/Wheel_Ada.../5500-5500.htm
Primer70 is offline   Reply With Quote
Old 08-31-2009, 07:06 PM   #7
pat386
misshape grape
pat386's Avatar
thanks! will the rearend bolt right on?
I got thewheels on craigslist. too good of a deal to pass up, so I'm gonna make it work. may just order 20x10's for the rear...but i would like to even find a rear end with rear disc brakes
Old 08-31-2009, 08:25 PM   #8
3r!c84
Badass
3r!c84's Avatar
yea then u would need to replace the master cylinder.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-31-2009, 09:13 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
No he would not. He would need an adjustable proportioning valve but the stock MC would work.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-31-2009, 09:15 PM   #10
3r!c84
Badass
3r!c84's Avatar
ok nevermind me lol
-00 Saturn 5spd
1/4:13:90
Old 09-01-2009, 08:25 AM   #11
nlped
nlped's Avatar
No, the 88-98 rearend won't just bolt in. You will have to cut off the stock perches and shock mounts and relocate them to the appropriate width for your box.
On another note, have you confirmed that all of the wheels have the same offset? Perhaps you have them on the wrong "end". Just a thought...
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-01-2009, 09:31 AM   #12
bigbadjohn84
yea. second that. just have to relocate the mounts. pretty straight forward. and on the master cylinder.. Im not sure. if N2Trux says it its gospel! lol
