Old 08-31-2009, 05:25 PM   #1
ChaStur
U bolt question ( lowered )
I'm in the process of leveling my truck off and have only one place to get custom u bolts made up. I want to run a 2" lowering block but they cannot give me one in the length suggested. Only shorter. With that said what's the minimum length I can get away with? Their over $20 each btw
And if that's not possible I can get 3/4" thread in the correct length.
Any suggestions?
ChaStur is offline   Reply With Quote
Old 08-31-2009, 05:34 PM   #2
fiddy9apache
fiddy9apache's Avatar
Re: U bolt question ( lowered )
im just goin by what info is in your post, might help if you gave us more info on the truck and current suspension.
so i guess you already have a flip kit and your wanting to drop it another 2in in the rear? instead goin through all the trouble of new u bolts why not run 2in drop shackles?
fiddy9apache is offline   Reply With Quote
Old 08-31-2009, 06:31 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I beleve there are places online to order u-bolts.
Don't settle for something less than a "full nut" of thread engagement.
Keith
Convert to disc brakes.
Old 08-31-2009, 06:35 PM   #4
ChaStur
Oops. It's a 70 with rear coils. I'm just trying to get a mild drop for winter and bags are getting put in this spring. Just hoping for a cost effective way to get 2" out of the rear.
I'll check online. Thanks!
Old 08-31-2009, 06:40 PM   #5
fiddy9apache
Jeep Tj (96-02) coils in the rear will lower it 3-4inches and its a simple coil swap.
