Old 08-31-2009, 07:06 PM   #1
blazer2007
any good header paint out there?
I haven,t painted any headers in awhile,is any of that new stuff like vht with ceramic work well.The stuff that comes on the headers doesn,t last long.
blazer2007 is offline   Reply With Quote
Old 08-31-2009, 11:48 PM   #2
baggedcten
86 C10
baggedcten's Avatar
Re: any good header paint out there?
i dont know, but i know that that duplicolor stuff sucks it burned off like in a week or two
1986 C10
2001 chevy silverado purchased 8-29-09 sold
2004 silverado purchased 8-27-10 sold
baggedcten is offline   Reply With Quote
Old 09-01-2009, 12:00 AM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I've never seen any "spray bomb" paint that worked on headers that lasted longer than a few days.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 09-01-2009, 03:50 AM   #4
dgas
The old VHT stuff works well ( I think it is now Mr Gasket or whatever Summit calls it now) BUT you HAVE to follow the directions to a T, the whole deal- sandblast, wipe clean w solvent -DO NOT TOUCH it w your bare hands!, Use plastic gloves. The oil in your skin will mess up the whole thing. Then cure per directions on the can. I used to have the same troubles until I actually did the whole routine including the warm up curing steps. I have a set painted white on a BBC car and they look great after 6 years w some yellowing around the ports is all.
1966 Chev LWB C20 PU
http://s41.photobucket.com/albums/e2...ev%20C20%20PU/
dgas is offline   Reply With Quote
Old 09-01-2009, 10:02 AM   #5
Moostifer
a fool with no money
Moostifer's Avatar
x2...
YOU MUST FOLLOW THE DIRECTIONS EXACTLY! from prep to cure... it's easier if you have an electric oven that they will fit in
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 09-01-2009, 12:32 PM   #6
Adams74Chevy
Adams74Chevy's Avatar
crazy idea just popped in my head how about the black paint wood stove since it's made for wood stoves it should be heat resistant, but aren't most stoves cast iron...just a crazy idea to throw out there.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 09-01-2009, 01:37 PM   #7
bobs84
Eastwood makes A good product called high temp coating .You brush it on run it for about twenty min. bakes it on. did my headers two years ago still look good
bobs84 is offline   Reply With Quote
Old 09-01-2009, 01:43 PM   #8
olblue81
olblue81's Avatar
John Deere muffler paint.
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
Old 09-01-2009, 01:48 PM   #9
joe231
joe231's Avatar
I have heard good things about POR 20
http://www.por15.com/POR-20-ALUMINUM/productinfo/P2G/
CHEVY ONLY
Old 09-01-2009, 03:15 PM   #10
blazer2007
I,ve also heard of rubbing tranny fluid on headers,burns the header black I,m told but haven,t found anyone who,s done it
Old 09-02-2009, 09:53 AM   #11
Moostifer
Moostifer's Avatar
also rids the area of mosquitos
