Old 08-31-2009, 08:05 PM   #1
noonzor
set something straight........
so i got into an argument with a buddy (who was gonna help me weld my frame after shortening) about how to cut the frame for sectioning. after consulting this site i stenciled out the step notch design, as ive read its the strongest and easiest for re-aligning when welding back together.
HE says that cutting at a 45* angle and taking the 12" out would be a stronger better cut as thats how they do things at his work.
are we both stubborn and right, or ....?
noonzor is offline   Reply With Quote
Old 08-31-2009, 08:10 PM   #2
bedsled71
bedsled71's Avatar
Re: set something straight........
either way you should plate it so it shouldnt matter
bedsled71 is offline   Reply With Quote
Old 08-31-2009, 08:13 PM   #3
FnLow69
FnLow69's Avatar
either way you'll be fine...just box that portion of the frame
FnLow69 is offline   Reply With Quote
Old 08-31-2009, 09:02 PM   #4
fixit-p
fixit-p's Avatar
I bet your buddy works on larger trucks, because thats how I do it at work. I measure down 1-1/2" verticle, measure back 10" and up 1-1/2" from the bottom and connect the two points on an 11" channel it's actually flater than 45*. I like the step cut on the smaller channel because it gives more weld surface and the horizontal weld is on the beams neutral axis the inside corners of the cut are always a high stress point so plate or box as already mentioned. You guys could always compromise and cut horizontal with 45* at each end (I've considered doing that on my 69) just my $.02.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 08-31-2009, 09:24 PM   #5
noonzor
excellent, is either way easier to re-align when puttin em back together? or are they both pretty straight forward?
Old 08-31-2009, 09:46 PM   #6
fiddy9apache
fiddy9apache's Avatar
i did mine at a 45* but if i woulda had the room to i would have done a step cut. but no matter what plate both sides.
fiddy9apache is offline   Reply With Quote
