08-31-2009, 10:14 PM | #1 |
front spindles
hey guys, read a few posts on here about if you use 71-72 disk brake spindles on a 70 and eariler there is a noticable difference in the width of the front and rear? just wondering if anybody got pics of there trucks that have done this? thanks
69 short fleet 350/350 "under construction" 70 short step 307/3 speed Last edited by redbaron69; 09-01-2009 at 08:44 PM. Reason: my lack for spelling words! |
09-01-2009, 06:54 PM | #2 |
Redefining LowBudget
Re: front spindles
i"m in I have been woundering myself for my 70
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
09-01-2009, 07:14 PM | #3 |
I am a Referee of life.
Re: front spindles
IIRC it's about 3/4 in per side.I do know my lowering spindles(on a 68) moved the fronts out about 3/4-1 in each side.If you're going to run aftermarket wheels and haven't ordered them yet you could adjust by backspacing.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-01-2009, 08:42 PM | #4 |
Re: front spindles
was looking at running the truck or vette ralleys, do you think these will be a problem? PanelDeLand, how much drop have you got in the front? im looking at a 2/4.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
09-01-2009, 10:10 PM | #5 |
Enjoying left field
Re: front spindles
I bagged mine, which makes the lower control arms horizontal instead of angled a little, and dropped spindles and disk brakes. I gained almost an inch and a half per side.
09-01-2009, 10:19 PM | #6 |
Re: front spindles
how do your wheels fit when you drop it I cupped my LCA so I get 2 1/2" more than you my tire just clear my inner fender support???? eeeeek.... I want drop spindle jst not sure if that and the disc brakes will get it to far out to clear??
09-02-2009, 04:20 PM | #7 |
Re: front spindles
Well, if the 71-72's move em out 3/4" then I can't wait to see what my 79' spindles look like! lol
1967 C10 LWB 454/TH400 1971 C10 SWB 1984 C30 LWB Dually 454/4 spd 4:10 2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison |
09-02-2009, 06:45 PM | #8 |
Re: front spindles
I have a 2 1/2 spindle drop.IIRC someone mentioned that there is a vendor selling spindles or maybe spindles and arms that bring the wheels back in.I don't know where I read that so I wouldn't know where to search.
I can see the difference in mine but most people wouldn't know.I'm running 6 lug rallies and someday may swap to a steely with offsets to correct.
09-02-2009, 06:51 PM | #9 |
Moderator
Re: front spindles
CPP now has spindles that will not kick out your wheels the additional 3/4" on either side. I saw a guy at Brothers truck show that was running them, and he said they were fantastic.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-02-2009, 09:26 PM | #10 |
Re: front spindles
I've got 2" dropped spindles from ECE with 1.5" dropped springs. The wheels are 15x8 all around. I don't know the back-spacing. I wouldn't worry about the 3/4" unless you plan on running 20's.
09-02-2009, 10:08 PM | #11 | |
Re: front spindles
09-02-2009, 10:08 PM | #12 |
Tot Roddin'
Re: front spindles
In the end the 3/4" on each side (1.5" overall) isn't that big of a deal, but there's a lot of factors you must consider.
Tire Specs Wheel Specs Which year rearend you are running? (67-70 was narrower than the 71-72) I recently dropped my truck 4.5" (2.5" drop spindle 2" drop spring) up front and I didn't rub with my 15x8 235 75R15's... however, they were a little to close for comfort for me. I was watching every pot hole to make sure I didn't bottom out on my inner/outer fenders. Also I didn't like the wide track from with a narrow rear end. If you are going to go big wheels (20"+) then you can order your wheels with the correct BS to accomodate the change. If you are going to run 5-lug setup, then you might consider upgrading your rearend as well. Just a few things to consider...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
09-02-2009, 10:13 PM | #13 |
Tot Roddin'
Re: front spindles
BTW... check out Classic Performance Parts (CPP) www.classicperform.com for more info on the modular spindle.
09-03-2009, 10:51 PM | #14 |
Re: front spindles
i like the height and wheels security guy. 20's are out for me, not my style. just wanting the disk setup for better braking. the 3/4 inch looks like it wouldnt be a big deal. will i need 71-72 ball joints for factory spindles? or are they the same for all years?
09-03-2009, 11:00 PM | #15 |
Old Skool Club
Re: front spindles
When I put the ECE dropped spindles on my '69, then reinstalled the same 15x8 wheels, I noticed that they were jutting out into the opening and could contact the inside of the wheel opening w/o any real warning. So, I replaced the front wheels with 15x7's and no more interference.
When I put a set of Wheel Vintiques vette-style rallye wheels on it, I went to a 15x8 up front with a 4-inch backspace and a 15x10 on the back with a 5-inch backspace. I like the way it sat and the way it looked. Looking down the side of the truck let me see that they were well-placed in spite of the fact that the front track is wider than the rear wheel track.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-04-2009, 08:48 AM | #16 |
Re: front spindles
hottrucks,I don't have a pic that shows the offset well.It's really only noticeable in a down the side veiw.I will try to get a pic this weekend.
09-05-2009, 04:30 PM | #17 |
Re: front spindles
Here goes
09-05-2009, 04:34 PM | #18 |
Re: front spindles
I hope you can see the difference from these pics.It's not much but if you know.....
BTW Those are 235/70-15 front and 255/70-15 rear on 8 in 15 rallies all the way around
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 09-05-2009 at 04:34 PM. |
09-05-2009, 04:37 PM | #19 |
Re: front spindles
well I found a deal if I can catch it on a set of 20's so I guess they will fit one way or another.... my only fear is the fronts and a 10" wide rim but we'll see soon enough if the wheels don't get sold I'm picking them up monday
09-05-2009, 04:40 PM | #20 |
Re: front spindles
I kinda would need a from the ground up view so I could see where it might hit the fender....or maybe a board against the tire up to the wheel well.....I might get and extra 1/4" because the a arms are pulling everything in a bit at drop
thanx by the way nice burb we never see any of those up in this part of the world
09-05-2009, 09:34 PM | #21 |
Re: front spindles
PanelDeLand,Security Guy thanks for the pics not as bad as i was thinking it would be. nice looking rides BTW
