08-31-2009, 10:45 PM | #1 |
tranny issues help if possable
ok so i swapped in a built 350 thats bolted up to my all stock turbo 350 trans after a day and a half the tranny started slipping is there anything i can do to make it slip less tell i have the money to rebuild it its my daily driver the truck is a 67 chevy swc lwb with a 71 frame
08-31-2009, 10:59 PM | #2 |
its all about the +6 inches
Re: tranny issues help if possable
not to be a smart A... but did you double check the fluid level?
If thats good, I guess you can tru any one of the fluid additive things, they are bad news on a good tranny, but since it is already junk, it can't hurt. |
08-31-2009, 11:48 PM | #3 |
fluid levels toppped off and already have lucas in it if only it would hook up better at ilde it be much better off once its around 10 mph i can fether the trottle to get some speed but it takes for ever to get to 10mph
09-01-2009, 06:45 AM | #4 |
soulds like it's game over
09-01-2009, 09:30 AM | #5 |
more ideas than money
Did you remember to put the bolts through the flywheel into the torque converter? I really dont know what happens if you don't, but that could be why it is all of the sudden bad.?>? I guess?
Randy 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
09-01-2009, 10:49 AM | #6 | |
Watch out for your cornhole !
Sounds like the trans needs some help.
09-01-2009, 10:58 AM | #7 |
usually when they start acting like that theres very few dependable miles left /especially after midnight in the middle of nowhere
09-01-2009, 11:06 AM | #8 |
Sawdust in the tranny? It's an old used car lot scam trick I learned about when searching for a car at the we tote the notes. It will make your tranny fail eventually, (probably sooner rather than later). But maybe it can get you back and forth to work for a few days, maybe. I am not advocating sawdust in the tranny, but I've seen it done. And no I've never done it to anyone, just almost had it done to me twice when I was young.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
09-01-2009, 11:10 AM | #9 |
Did you completely fill up the torque convertor with fluid when you put the tranny on? Also make sure you seated the torque convertor all the way before you bolt it to the fly wheel. If not, and you tightened up the torque convertor without it being seated all the way you may have broken or cracked the sun shell. I've done that before, too.
Shawn
09-01-2009, 04:22 PM | #10 |
i never pulled the tranny when i put the new motor in it did leak a little but not much so i filled it back up and it was fine for about a day and a half before it started slipping and is slowly getting worse i just need it to last long enoght for me to save up $600 to have it rebuilt and a shift kit put in
question what company do u guys sudgest i put in it |
09-01-2009, 04:39 PM | #11 | ||
