Old 08-31-2009, 10:58 PM   #1
dammitmitchell
the pollock
dammitmitchell's Avatar
slider bar/ additional jack point
hey gents, nearing the end of my project here and now it's getting to time for the rocker pannel repair
i was wondering
has anyone or does anyone have a reccomendation for running some square tubing below my rockers for a slider bar or a additional lift point?
got any ideas?
i was thinking two or three inch square tube, then i can run the supports to the frame and bolt/weld them to the frame
wanting to do this the same time i make an "X" for my rear frame
i'll be putting a trailer hitch in (just bolt on) but then boxing the frame near it with pretty much a large "X" so while im tugging folks out of the mud i quit twisting parts back there...
thanks for inputs... and pictures are even better!
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 09-01-2009, 06:50 AM   #2
vtblazer
vtblazer's Avatar
Re: slider bar/ additional jack point
Two option's:
Go square tubing or perhaps something more...
If you were closer, I'd give you the square tubing I pulled off.
vtblazer is offline   Reply With Quote
Old 09-01-2009, 06:52 AM   #3
vtblazer
vtblazer's Avatar
Couple more pics of the square tubing and how it's mounted, sorry those are all I have.
Old 09-01-2009, 10:23 AM   #4
Burt4x4
Burt4x4's Avatar
My gallery is down at the moment so no pics to share...
I used 2x3 square tubing. But I removed both outer and inner rockers(rusted) and welded the tubing directly to the rocker box and body pillers....basically cut out a spot, floor jacked up the tubing welded it in place
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-01-2009, 03:39 PM   #5
dammitmitchell
the pollock
nice thanks gents!
Army vet 02-08
Old 09-01-2009, 11:18 PM   #6
onlyifihadachevy
Was going to say what they said, and you could weld some a sheet of steel with dimples onto the tubes.
I think what your thinking about the back x would work too, but at the end of the frame hammer some c channel on then weld it it will make the frame more solid. similar to this but ending over the rails.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 09-02-2009, 02:08 PM   #7
84 400
Sb 400 club
84 400's Avatar
just be careful how and where u mount it. These frames are designed to twist right after the cab and a solid mount strattling this point will cause tears if not done right. I think petersons did a write up on this on a CUCV they where building . I want to ad some to mine also rock sliders seem very usefull. I know alot of companies make em for K5's but have not seen any for trucks. ORD had talked about it but i don't think they ended up doing it.
Here is the article!
http://www.4wheeloffroad.com/brandpa...k_3/index.html
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
