1991 Suburban 454 heat issues
I installed a 1991 Suburban motor in my 69 crew cab truck and put in Autometer gauges. I am having a problem with the temperature gauge reading hot. I had the sending unit in the right head and the gauge was showing that it is running 210 in the driveway but when I took it out on the freeway it went up to 250. I moved the sending unit to the thermostat housing and now it reads 180.00 all the time. Can the sending unit next to the exhaust make a differance in the reading? I am running a Edelbrock reverse flow water pump and a be cool radiator and it seems like it is running cool but I am worried about the reading from the head.
Low & Fast!
Re: 1991 Suburban 454 heat issues
Your header could make some dif with it, but I would not think that much.
Thanks, the motor was recently rebuilt and only has 80 miles on it and I am thinking it still might have an air pocket in it.
try an infared gauge (point and shoot) to see what temps you are getting
I did that today and the temp on the heads was 185 and the radiator was 140 and the intake was 180. I put a sender in the thermostat housing and wired it to the temp gauge and it showed 180 and that was with it sitting for about a 1/2 hour. I moved it back to the head and the temp jumped to 250. I called Autometer about it and after following their suggestions it still does not work right.
![]() Join Date: Dec 2003
I had the same problem with my 454 with a stock temp gage. Moved the temp sensor from head to head. Even got a new sensor, nothing helped. Got a new gage and wired it in and verified it was the gage.
I am thinking of putting in a mechanical gauge and see what it says.
well at least you know is a gauge issue and not an engine problem
they like to trap air around the sendors and cause that problem. eventualy it will go away.
Thanks for the replies, it is driving me nuts trying to figure out why it will not read right from the head. Thanks
Low & Fast!
Good luck with it..
