Old 09-01-2009, 09:58 AM   #1
67c-10Texas
73-87 RADIATOR - will it fit
Will an 73-87 radiator fit in my 67 - has it been done? any modifications to the support??
i tried a search but i could not find anything.
thanks
67c-10Texas is offline   Reply With Quote
Old 09-01-2009, 10:39 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 73-87 RADIATOR - will it fit
The 73-80 ones fit no problem. The 81-87 units are taller and require modifying the upper hold downs. I just welded a small spacer to the 67-72 upper retainer to make it fit the taller radiator.
The lower hose bung won't be angled up like stock, but a 73-87 hose works fine.
Old 09-01-2009, 10:46 AM   #3
Tx Firefighter
I found some pics I took of this mod. I used an 83 radiator in my 72. It was too tall. Everything fits fine, it's just taller. I used 3/4 inch angle iron to modify the stock 72 upper retainers. If you use a 73-80 radiator, no mods required at all.
Old 09-01-2009, 10:55 AM   #4
67c-10Texas
looks sweet - should be no problems with a 67 - slop of hood should not interfear?
found a be cool new in box for 350
Old 09-01-2009, 11:06 AM   #5
Tx Firefighter
You'll be fine with the sloped hood.
