Old 09-01-2009, 01:04 PM   #1
vegaschevy
Rear Bumper to Frame size bolts
What are the sizes and lengths? I am pretty sure ill need washers and nuts so thread pitch probably not to big of a deal.....
and if anyone knows the front as well for that matter let me know.
vegaschevy is offline   Reply With Quote
Old 09-01-2009, 01:42 PM   #2
lks dcvn
lks dcvn's Avatar
Re: Rear Bumper to Frame size bolts
Cheapest - head to a Tractor Supply Store and get the carriage bolts with washers, lock washers and nuts.
I got a set for front/back with everything I needed in the bulk bolt section and they were about $3-4 for everything. I got the same size for both front and back.
I think I used 1 1/2" bolts - maybe less - can't recall for sure - I think they have 1/4" increments on the bolts [1"; 1.25"; 1.5"; etc.]
There will be some lettering on the bolt heads and if you want them gone - angle grinder will take them right off and polish them up.
lks dcvn is offline   Reply With Quote
Old 09-01-2009, 02:24 PM   #3
vegaschevy
i meant a bumper brackets to frame bolts. the carriage bolts are for the bumper to brackets right?
Old 09-01-2009, 03:22 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
1/2 inch bolts are what you need.
Old 09-01-2009, 03:50 PM   #5
vegaschevy
Do you think 1/2 inch by 1 1/4 would be long enough?
Old 09-01-2009, 03:51 PM   #6
Tx Firefighter
That sounds long enough. Use good flat washers too.
Old 09-01-2009, 05:56 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
and, in case we aren't all on the same page here... 1/2 inch bolt, Kevin means the bolt diameter... that would be 3/4 inch hex head/wrench.
Old 09-02-2009, 02:58 AM   #8
vegaschevy
Got some earlier today. Going to get my seat installed, bumper installed, and get this truck running!
