01-13-2003, 12:10 AM | #1 |
4x4 power steering question
i am wondering if anyone knows what the difference between 2 and 4 wheel drive power steering set ups. i know where i can get a 2 wheel drive gearbox cheap, will this work and how much would the pump set up cost? anyone got any answers?
thanks |
01-13-2003, 01:17 AM | #2 |
Recovering 67-72 Addict
The 4x4 boxes have a thicker pitmam shaft and the pitman arm is different.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
01-13-2003, 01:50 AM | #3 |
aka Crusher, Crushergmc
Also, the 4x4 box turns in the other direction (I think). Pump should be the same.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
01-13-2003, 11:38 AM | #4 |
Difference is in the steering gearbox itself. The 4wd moves the pitman arm front to rear while the 2wd moves the pitman arm side to side. Thats the reason guys switch to a 2wd box when they install crossover steering setups. You need a 4wd box for conventional 4wd use. Trukman1
